¡Hola amigo su problema es exclusivo del control remoto de su tv al parecer esas teclas ya no le funciona valla al panel del tv si ah? no le funciona tampoco yo le recomendar?a revisar el panel del tv presione en su control el mute si trabaja el sonido de su tv esta bien si el volumen continua fijo despu?s de revisar el panel y este estar funcionando bien entonces es un problema de la m.b del tv o sea la placa principal a veces una falsa soldadura es todo el problema espero q resuelvas tu problema..
Testimonial: "thanks but i can not read ..."
SOURCE: JVC LCD TV LT-42X688-powers on, blank screen. no picture,no sound
You most definately have bad capacitors in the power supply. try and get it repaired as soon as possible, not an expensive repair that iv'e seen.
SOURCE: need help with TV calibration for philips
Try these,
Contrast: 53 Brightness: 56 Color: 45 Tint: 2 Sharpness: 2
Color temperature: Off
Dynamic contrast: Off
Digital Natural Motion: Off
DNR: Off
Color enhancement: Off
Active control: Off
SOURCE: 42" Vizio - no picture no sound
If the TV goes in standby, then it is in protection mode.
Ensure also that the fault is not coming from a faulty receiver box sending
bad signal, check if you get same problem on DVD with no receiver box
connected.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible causes.
1The
internal circuits are jammed because of electrostatic
charges accumulating on capacitors, or because of a wrong voltage read
by the main chip on your monitor controller board. this started the
protection circuit.
2 The protection circuit detected a wrong
voltage or abroken contact, identified an internal fault and kicked in
, starting the flashing light.
If you are in situation one, then the TV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
On LCD Pay
particular attention at inverter and power board, power board can be
inspected looking for bulged or leaking capacitors, then tested with a
multimeter. The inverter is more difficult to test , there is need to
read voltages, should be done by a tech. Also the LCD controller board can cause same problem
SOURCE: 42'' lcd turns on no picture/menu
Your tv is being attacked by electrical surges which seem very violent and has already damaged some logic controls. Please invest in a AC filter which will protect your tv from such spikes....... but first you need to get your tv serviced from the electrical damaged it has already suffered.
