If you can fold your stroller correctly check the seat first. It might have got jammed. If the seat is ok you have to follow the free stand button replacement guide. The problem might be causing for internal malfunction. Visit here for more: Best Double Stroller 2017 10 Top Sold Strollers Of The Year
SOURCE: Bugaboo bee pram won't fold - the white button has jammed. How do I releas it?
Not an easy fix the handle unit is all closed in with pop rivets so you need a drill and pop rivet gun just to open it. Try spraying silicon spay in to the inside of the handle where ever can then pull up ******* the release buttons while flexing the joint back and forth.
SOURCE: the backrest adjustment lock (white
I had the same problem. The stroller was not fully unfolded. Verify if the you have heard the clicks on both sides and the green spots on top of the handlebars are completely visible.
Check all the wheels. Sounds like one is broken or has a bad bearing in it. Try In that case you'll have to order a new one and replace it. In looking at reviews for this buggy, it seems like a common issue.
http://www.lilimay.com/buggies/bugaboo/spares.php
