Washing Machines Logo
yeny alfaro Posted on Dec 29, 2016
LTE6234DQ1 belt replacement - duet Whirlpool Washing Machines
2answers
If I replace timing belt 97 quest van do I need to replace camshaft belt tensioner
any time a vehicle has a hydraulic tensioner it should be replaced. most parts stores have a timing belt replacement kit. some have the idler pullies and the tensioner and belt. you should replace the water pump while you are in their.
2answers
Belt keeps slipping on treadmill and belt is all the way back
If you have adjusted the tension on your belt to the max, it is more than likely time to replace your running belt. The running belt naturally stretches over time. I would suggest replacing the belt and flipping your deck. If the deck has already been flipped once, then you would need to replace the deck as well. Life Fitness Treadmill Belt and Deck Replacement Video 95T
1helpful
How often should you get engine belts replaced and what belts need to be replaced?
Replace belts as needed, check for cracks on the sides of the belts or pieces missing from belt. A good belt should last 100,000 miles. and it is a good practice to replace at 100,000 even if it looks good. REPLACE ALL BELTS as needed.
Hello, I have a stacked Whirlpool washer/dryer. (Model # LTE6234DQ1) I wish to move it down a flight of stairs and want to know if this model can be easily 'unstacked' for the move. Thanks for your...
Hi there.
Yes it can.
Access bolts to the feet should be visible from the rear of the unit. Failing that, the top screws of the bottom appliance should undo, and the top appliance (with lid of lower one) should slide back 1" allowing it to be taken off.
Be careful not to damage this lid section in the move, and further removal can restore it back to two appliances again.
If this helps, Please take a moment to rate as Fixya! Thanks.
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
