When I push the power button the brew light flashes. I mashed it then the add water light comes on I add water then nothing happens the add water light just keeps flashing. What can I do to fix it????
To get a proper suggestion, you have to include the make & model of the machine/coffee maker.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edward_bbd2c7ff4ee1828a
SOURCE: coffee maker won't brew
This one has two AUTO dial settings - AUTO-ON and AUTO-OFF. AUTO-OFF merely keeps the hot plate warm for a fixed period of time. AUTO-ON is the one that allows your coffeemaker to go off at the pre-programmed time in the morning.
If it is set to AUTO-ON, but is not brewing at the set time, unplug the machine for longer than 20 minutes. Then plug it back in, reset the clock, reset the prog time for a time that is just a few minutes into the future, and then test the auto-on feature.
If it stil ldoes not brew, just turn the machine to brew and press on. If it brews a pot, then your problem is electrical. If it doesn't brew a pot on the regular brew setting, then you either have: A) Calcium buildup/clog, or B) a hose leak (or worse).
To rule out the calcium buildup possibility, let half a caraffe worth of vinegar sit in the water reservoir for about an hour. After the hour, turn it to brew and press on, and brew the vinegar just as if it were coffee. If the vinegar goes through, your problem is solved.
Otherwise, call Cuisinart and find out if you are still in-warranty. Thep roduct has a 3-year warranty.
-Tha Mp3 Doctor
SOURCE: Light keeps flashing and water will not heat
there is a float at the side of the machine by the water level, if the float gets stuck the red light will continue to flash even though water is present. Use a magnet on the outside of the machine by the water and float level and raise the float when connected to the magnet and the light will stop flashing red rapidly
SOURCE: WIll not brew
Try this, worked for me:
Just today we've found that at the first water intake (on my B60,
that's where the water container plugs into the base) on the base is a
little circle valve type thing. That's where the water gets sucked out
of the tank. Shine a flashlight into that circle, and you'll see a
screen type thing there. It's like the screen in your faucet when you
unscrew the tip and there are little rocks and stuff in it? Same
principle: there were cotton fibers and other assorted weird stuff
clogging that screen. Used a toothpick or a needle and removed all the
debris from the screen, and it now works perfectly!
SOURCE: Coffee not brewing after grinding
After grinding did you hear the brew group goes up and pump start? If you hear the pump start and stopped, itis blockage in the brewunit metal screen. Just needs cleaning.
If you don't hear the pump starting, the problem is with the faulty micro switch inside the gearbox , that is behind the plate of brewunit.(service center job)
SOURCE: coffee maker beeping
Is your grinder in and the lid down? My coffee maker (grind & brew) started beeping after I cleaned it and turned the left knob clockwise with the grinder still disassembled. There's a little button that is depressed when you close the lid with the grinder in there (I'd guess it's a safety feature). I pressed down that button, and the beeping went away.
