Question about Honda Electrical Supplies
Honda EM 5000 SX generator.
New Carburetor, new plug, new gas with enzyme additive for ethenol. When it starts to warm up it start surging. When warm RPM Drops and gallops
SOURCE:
  • 623 Answers
SOURCE: Honda EU3000is generator will not start with electric starter.
I'd say your battery in the generator is going bad or bad. They are very small and do not hold a charge for very long. The noise you heard was probably the starter shaft hitting the flywheel cogs. I doubt any harm was done as long as you did not repeatedly try to start it with the key. Why Honda put a battery in these is because they are intended for use in a campground setting, where they would be used on a daily basis and the battery would constantly charged. Whereas people like us buy them for emergencies only, they sit for long periods, and the battery goes flat, and the fuel clogs the carb and we get the surging issue. That's my 2 cents. When I brought mine home new, I Sta-bil'd the heck out of the gasoline, this past winter, on start-up, the unit surges. Of course the battery was flat.
Posted on Mar 17, 2009
mamicheddy
  • 79 Answers
SOURCE: I have a Generac portable generator 5000 watts, won't start!
I am assuming the generator worked fine before the oil change. Now that you have done the oil change the genset does not start. These generators have a safety switch, which is basically an oil pressure switch that keeps the engine from running when there is not enough oil in the engine. Make sure that there is enough oil and if there is, look for a wire that runs along side of the engine to a round component. disconnect that wire and try starting. If it does not start then try to ground out the wire to the engine block. If this does not work, then there is other engine problems.
Posted on May 08, 2009
smartr10U
  • 1305 Answers
SOURCE: Coleman Powermate 5000 starts with starter fluid, but leaks
Sounds like you need to clean the carb ports, lines, jets, etc... purchase a carb spray cleaner with a tube to place on the spray head (Berryman's Chemtool B-12 is awesome). Take the carb loose from the generator, and remove the bowl, needle valve and spray carb cleaner thru all the holes, lines in the carb. Reinstall complete with air cleaner and retry... also if the gas is old, drain and replace with new...
Posted on May 25, 2009
  • 57 Answers
SOURCE: Generator with Briggs & Stratton,no gas is getting in carburetor
The needle valve may be stuck which would not let gas into the carb. I don;t think rebuild kits are too expensive. Pull the carb and take it to a lawnmower repair shop and they should have the parts. Before that though pull the bowl and make sure it has gas in it. If no then remove the fuel line and make sure gas flows from it. If no then could be the fuel shutoff valve is not operating properly or junk in the gas tank is obstructing the line.
Posted on Jul 31, 2009
SOURCE: Coleman 5000 watt generator Tecumseh 10 hp engine.
it's running lean.....try resetting the choke partially when it begins to surge.....not completely closed, but enough to richen the fuel mixture (that's all a choke does btw..)
if that helps or clears the problem, your carb is outta whack.....cheaper to buy a new carb than keep taking back into the shop.
Posted on Feb 01, 2010
Ex1000 honda generator getting no gas to sparkplug. new plug,, dry when taken out after trying to start. generator has sat for 1+ year
Carburetor, injectors likely gummed up. It is a common problem. Try spraying carburetor cleaner into the intake and get it to run briefly by burning the cleaner. Keep trying that until you get it to run.
Oct 02, 2018 | Honda Electrical Supplies
Ex 5000 sx generator, no power
Hello dear, would you consider buying a new generator? Generator Diesel Generator Cummins Generator Volvo Generator Perkins...
If you can start your generator normally, you can analyze the reasons through the following article:
Why Diesel Generator Fail to Start
Simple Ways to Deal with Diesel Generator Failure
Hope it works for you.
Sep 21, 2017 | Honda Electrical Supplies
Huffy 5000 gen. started once after purchase then gas drain and gen stored. will not start now. new gas in tank, oil has been changed, spark at spark plug ( good not great) old gas drained from carb bowl,...
Hi men2cu...
Try this method, being you have spark and gas getting to the carburetor...
Get a can of starting fluid, and spray a small amount of it into the carburetor and then try to crank it again...if it cranks and runs then problem fixed...if it cranks and shuts off right away, then you have some trash in your inlet valve in your carburetor.
You can try tapping the carburetor lightly with a hammer and sometimes that will dislodge the float needle if it doesn't dislodge the needle valve then the carburetor will have to be disassemble and cleaned.
Once this is complete your generator should run fine.
Please take time to rate me
Aug 23, 2011 | Garden
My Coleman 5000 generator in storage. Gas tank was drained. New gas put in. Won't start. Gas poured down spark plug hole. l Engine will start but stops and won't start again. Is it a carburetor...
It sounds like your carb needs to be taken apart and cleaned out. The gasoline in the carb sounds like it has varnished and blocked the passages in the carb. I would try some carb cleaner, if you are comfortable in taking apart the carb, you can use the spray cleaner to open the passages. You might have to soak the carb a bit as well.
Mar 07, 2011 | Garden
I want to buy a power arc 5000 but i want to know about **** durability
The Power arc 5000 gen. is really durable. I have had mine now for 5 years and have had no problems with it I use it for all my power tools on job sites.
Mar 01, 2010 | Lincoln Electric POWER ARC 5500 HONDA
Onan Marquis Gold 5.5 HGJAB 1038C. Won't start.
Test the solinoid with an ohms meter and if the circuit is open replace the solinoid.
Oct 22, 2009 | Watts Onan Portable Generator - 5000 ,...
Honda GX160 runs fine for 5 minutes then dies like out of fuel.
I would look for the fuel filter. Blow it our. I know you have a new tank of gas, but you might want to empty it out and make sure the clean and put in new. Even with Stabil in the gas you might just have to much condensation in the tank
Sep 07, 2009 | Master Heaters MASTER HONDA POWERED...
Honda Pressure Washer HP 5 not starting
You can try spraying some carburetor cleaner into the carb. If it starts for a minute, your carburetor need cleaning. When you added new gas did you remove the old gas first? Is the air filter clean?
Jul 18, 2009 | Honda 8 HP Engine
Surging 5000w Coleman Generator
I had a Colman that only surged when it had a large load on it. ConsumerReports.org says that some Coleman generators just can't hold a constant voltage. Hondas are expensive but very good,.
May 08, 2009 | Coleman Powermate Powermate 5000W...
Electrical Supplies Logo
128 people viewed this question
Top Honda Electrical Supplies Experts
John Trevino
Norman Al-Anbar
Sheldon Dedek
Are you a Honda Electrical Supply Expert? Answer questions, earn points and help others
