Since the start relay is clicking it is likely closing the circuit and sending voltage to the dryer motor. You may have a defective thermal limiter fuse blown, it is near the dryer motor so you must remove the back or front of the dryer to access it for testing. Always unplug the dryer before any work is done. You will need a DVOM meter (about $10.00) to check the fuse for continuity.
SOURCE: MODEL # RDE350AW HAIER HAS POWER BUT WONT START
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
SOURCE: picture of thermal fuse on haier rde350aw location to be removed and tested.
More than likely a bad heating element
SOURCE: where is the thermal fuse on haier dryer rde350aw located
Inside the back attached to the exhaust plenum.
