1997 Toyota RAV4 Car Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Blue/Yellow
Car Radio Accessory Switched 12v+ Wire: Gray
Car Radio Ground Wire: Brown
Car Radio Illumination Wire: Green/White
Left Front Speaker Positive Wire (+): Purple
Left Front Speaker Negative Wire (-): Violet
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Blue
Left Rear Speaker Positive Wire (+): Black
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Red
Right Rear Speaker Negative Wire (-): White
SOURCE: need wiring diagram for 1997
http://www.therangerstation.com/tech_library/radio_wiring_diagrams.html
detailed description of ranger wiring
SOURCE: toyota rav 4
I can get you a diagram on monday but it goes from the alternator to the power steering pump then around the tensioner pulley then around the crank pulley then to the a/c compressor then pull on the tensioner to give you some slack and slip it on the waterpump.I hope that helps.Let me know if you still need the diagram
SOURCE: 1998 toyota ipsum car stereo wiring
Clck here for the correct wire colors for Toyota. http://www.autotoys.com/New_Tech/Wire_codes/TOYOTA_WIRE_COLORS/toyota_wire_colors.htm
SOURCE: toyota land cruiser 1997 80 series electrical wiring diagram
what are the colour of the wires for the unlock / lock for the central locking for a toyota landcruiser 1990 modle ?
For
more help on car radio problems, I suggest you to go through these
troubleshooting links, these will help you: -----
Click
the link below: ---
http://schematicsdiagram.blogspot.com/2011/12/how-to-wire-new-radio-on-1990-toyota.html
http://schematicsdiagram.blogspot.com/2011/12/radio-stereo-wiring-diagram-for-1991.html
http://repairhelpcenter.blogspot.com/2011/11/how-to-remove-radio-on-acura-car-models.html
http://schematicsdiagram.blogspot.com/2011/12/where-is-radio-fuse-located-on-2007.html
http://howtobyme.blogspot.com/2011/12/how-to-reset-radio-code-after-car.html
http://schematicsdiagram.blogspot.com/2011/12/can-car-radio-code-block-passkey-anti.html
http://schematicsdiagram.blogspot.com/2011/12/after-market-stereo-wiring-for-1999.html
http://schematicsdiagram.blogspot.com/2012/01/chevy-car-radio-doesnt-allow-to-switch.html
http://repairhelpcenter.blogspot.com/2012/01/no-power-to-radio-on-2005-toyota-scion.html
http://repairhelpcenter.blogspot.com/2012/01/lexus-rx330-radio-has-power-but-no.html
http://technoanswers.blogspot.com/2012/01/radio-goes-on-and-off-while-driving.html
http://technoanswers.blogspot.in/2012/02/lincoln-town-car-radio-stereo-wiring.html
http://technoanswers.blogspot.in/2012/02/radio-wiring-diagram-for-1997-lincoln.html
http://technoanswers.blogspot.in/2012/01/how-to-remove-cd-player-from-dash-on.html
These
details will help you thanks.
For
Click
the link below: ---
These details will help you thanks.
Cigarette
lighter, Remote central locking, and Radio stopped working
http://whoisbyme.blogspot.in/2012/07/cigarette-lighter-remote-central.html
VW passat radio off safe
mode? VW radio CODE?
http://schematicsdiagram.blogspot.in/2012/03/vw-passat-radio-off-safe-mode-vw-radio.html
How to wire new Radio on
1990 Toyota Celica?
Radio Stereo Wiring Diagram
for 1991 Chevy 1500?
How to remove radio on
Acura Car models?
Where is Radio Fuse located
on 2007 Dodge charger?
How to reset Radio code
after car battery is died?
Can car radio code block
Passkey anti theft system ?
After Market Stereo wiring
for 1999 Chevrolet Silverado 1500?
Chevy car radio doesn't
allow to switch to the XM Band to get the radio ID?
No power to radio on 2005 Toyota Scion Xb?
Lexus rx330 Radio has power but no sound?
Lincoln Town Car Radio stereo
wiring?
Radio wiring diagram for 1997 Lincoln Town Car?
How to remove cd player from dash on 2003
Lincoln Aviator
