SOURCE: Changing announcement on Avaya Partner ACS phone
Selector code 3 is playing an announcement. You have to go into programming, press selector code 3. depending on the voiceail yu have....you may be able to modify it right there.. Other wise you willl have to find the annuoncements.
If you repost with what voicemail model it is, i can tell you exactly.
SOURCE: Panasonic KX-TG5673PK 5.8ghz phones.This post
Check that you are using your local answering machine on phone, and not a message recorded in phone provider company service. For example if you are using AT&T check that you are not using the message recorded on At&t, in tht case you need to set up service by phone.
SOURCE: rerecord the outgoing announcement
Hi, Press feature 9 8 3, display shows: Log: QUIT RETRY OK, enter system coordinator mailbox and password ( default is 102 0000 ), press OK, display shows: Admin MBOX AA OTHR, Press AA, display shows: Auto Atdt Admin GRTG TABLE LINES, Press GRTG, display shows: Greeting Admin GRTG AA, press GRTG, DISPLAY SHOWS: Greeting: RETRY OK, enter greeting number ( 1 to 20, usually 1 is the Main Greeting ), press OK, display shows: Greeting < X >, RETRY PLAY REC, press REC, at the sound of the tone record your greeting, press OK to end recording, display shows: Accept greeting? RETRY PLAY OK, press OK when you are satisfied. Good Luck
SOURCE: lower the volume or disable page/announcement?
For paging u can't change the volume. The only way is to reduce ur phone's speaker volume.
Thanks.
SOURCE: the privacy announcement wont go away and i cant get confirmation
Why is my account not been confirmed?
