My side-by-side Samsung refrigerator front temp control panel display was flashing and icecream was melting when I get home today. Reset power to it. The temp display became normal and the refrige side is cooling down to 34F, however the freezer side is still 61F. It seems that the bottom inside the freezer is colder than the top. What is the problem?
SOURCE: Samsung RS2533SW freezer not cooling problem
I was having the same problem but with the refrigerator side. I know your problem was with the freezer side but I hope this works in your situation too. I was also told to unplug the fridge for 20 minutes and that did not do a thing to reset the circuit board in my situation. Unplug the refrigerator first. In the back of the refrigerator at the bottom is a metal panel. Remove that panel and off to the right side of it should be a white looking plastic box. Unscrew that box from the fridge and open it up to get to the circuit board. Remove ALL harnesses from the circuit board and capacitor. After doing so plug them all back in and reassemble everything back together and plug in the fridge. This should reset the board and allow it to function correctly. This is advice I got from someone else and everything as of today is cooling down like it should. I hope this helps everyone else out. Best of luck.
Also since the evaporator was frozen solid at the bottom on the refrigerator side I had to leave the power off until it thawed and then had to soak up all the water that collected at the bottom of it.
I have this exact same issue. This morning the freezer temp display was flashing 0, ice melted all over the place, but the fridge part was fine. I unplugged it for 9 minutes per the Samsung help number to reset it, and now it's not flashing but it says 61. It does seem cooler at the bottom but I don't know if that's because of the stuff we had in there or not. The freezer part is definitely not getting any colder. The fridge part works just fine though.
[email protected]
I came home today to reset my fuse box. When I did so it appears that my Samsung RS2533SW fridge didn't like it. It is 5 years old and I have had nothing but problems with this appliance. I will never buy Samsung again.
what temp should by samsung freezer be set at
model rs261mdwp had power outage and only one blinking light on front panel...seems to be cooling...how to reset panel
control panel display four 8's. Far right one is blinking at top and control will not reset
Samsung RS2578BB Side by Side Refrigerator not getting cold and fan motor not running
We had a momentary power interruption and now display has a 5E flashing. Nothing I do will bring panel back to normal. Frig is cooling okay. Last time this happened it reset itself. Has been 24 hours now.
