SOURCE: 50 inch rear projection hitachi
Hi Roy
This problem can be a number of things. First I would say, check to see if Fan Exhaust on back is blocked. It must be atleast a 2 inch min. If this is ok then, There are a few parts inside you could change starting with I-901 and C-958. For more info you can visit ctechnicians.com
SOURCE: TV turns off while watching it then turns back on after abt 1 min
TV needs new lamp as symptom shows existing lamp is weak and causing repeatedly on-off
Please replace lamp in TV, replacement procedure is written in user manual and it is not difficult.
Always buy Sony original lamp for TV safety.
Let me know if you need further help.
Thanks.
SOURCE: my tv turns on but
To
solve this problem, follow the link below and follow the instructions
on the linked page 14 on how to solve this problem. For me to give you
instructions here, it would be too long so I set up this link that will
take you to solve the problem you're having http://download.p4c.philips.com/files/5/52pfl7422d_37/52pfl7422d_37_fur_aen.pdf#search=tv%20turns%20on%20but%20turns%20right%20back%20off
SOURCE: best plasma TV HDMI
None.All Plasma tvs designs are alway have high heat output and consume alot more A/C power energy than any other tvs designs out there.Tvs like CRT-tube tvs,DLP tvs -Projection tubes and projection lamps tvs,LCD-flourescent tubes tvs as Liquid crystal display screen tvs.All these tvs designs are all good tvs designs to buy but the pictures display and screen lighting and the sharpness of the pictures never have and able to compare high enough qualities as a display picture on the screen output to a Plasma screen tvs,until now LED-tvs are LCD and LED screen display combine to make it better and brighter technologies and now are good enough to compare to a Plasma screen panel tv.So buy a LED tv will get less heat output and comsume less A/C power energy too and it is good enough pictures qualities too.To compare too as a plasma screen panel tvs output.
