Cameras Logo
A
Alan Winton Posted on Dec 25, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have just purchased a Tokina 100mm F2.8 for my Nikon D610 and cant get it to Autofocus the lens is deffo in the right mode.
Bart Pulverman
Level 2:
Guru:
  • Nikon Expert 362 Answers
  • Posted on Jan 02, 2017
Bart Pulverman
Nikon Expert
Level 2:
Guru:
Answers
362
Questions
0
Helped
83658
Points
625
Looking at a photo of the Tokina 100mm f/2.8 AT-X M100 AF lens, I noticed that the barrow of the lens has two lines engraved behind the focusing ring labeled AF and MF. Are you sure that the lens is set to AF? If it is in fact in the AF mode, you probably have a defective lens. I would return it and ask for a replacement or refund.
Auto focus failure
My experience with lenses is that they either work or they don't. If it does not work "as you usually used it", then there is a problem inside the lens and not something the average photographer can repair. Lenses are quite fragile, a slight knock on one occasion can damage the inner bits which are very intricate and more so with motorised lenses. I have experienced a battery problem error message through a damaged lens housing and the battery also subsequently got damaged through short circuit inside the lens mechanism. Send it for a check-up and repairs!
I would like a 35-105 or 35-135 lens for my nikon f90x which one can i use
The F90X can use just about any Nikon-mount lens made in the past half-century, with the exception of lenses specifically designed for digital cameras with smaller sensors.
Nikon currently makes two 24-120mm lenses:
http://www.nikonusa.com/Nikon-Products/Camera-Lenses/index.page
Among older lenses there are autofocus 24-120mm, 28-105mm, 35-105mm lenses:
http://www.bythom.com/nikkordb.htm
There are a number of third-party lenses as well, from makers such as Sigma, Tamron, and Tokina.
2helpful
I have a Nikon F55 fitted with a NIKKOR AF 28-100mm lense I wish to upgrade to digital. Can I use this lense on a digital body?
Yes. In general any Nikon lens made in the last half-century will work on the newest Nikon cameras, and this lens is no exception. Be aware that on most Nikon bodies (everything except the D700 and the D3 family) the smaller sensor will make the lens behave as if it were a 42-150mm. Also, on the lower-end bodies such as the D3000, this lens will not autofocus.
1helpful
Bought a Sigma DG 70-300mm 1:4-5.6 autofocus for my Nikon D40. When the lens is attached the settings get locked on MF. Is there anything I need to adjust to fix this problem? Charles
The Sigma 70-300mm f/4-5.6 DG will not autofocus with the D40 since the lens does not feature an internal focusing motor (HSM). The D40 does not have an AF motor in the body and hence it can autofocus only with lenses featuring an integrated motor (eg. Nikon AF-S lenses, Sigma HSM lenses, Tokina DX II series etc). Unfortunately you can use the said lens only in MF mode.
I just bought the Tokina SD 12-24 F4 (IF) DX wide-angle lens for my D70, and it does not autofocus. I'm being told by the company I bought it from that i am past their 2 week return policy. Does this lens...
Only the MkII version of this lens has an autofocus motor built in, the MkI relies on a motor in the body of some Nikon AF SLRs to autofocus. The D70 does not have an inbuilt AF drive motor, so if you have the MkI lens then you can only use it in manual focus mode on your camera.
Tokina f2.8 100mm macro nikon mount. setting apature and shutter speed. little manual with lens not very informative.
Turn the aperture ring to the smallest aperture (largest f/number) and lock it there. Set the aperture and shutter speed on the camera body. You didn't specify which camera you're using, so I'm afraid I can't give you details there.
You will find all the information in the camera manual, not the lens manual.
Tokina f2.8 100mm macro. setting apature and shutter speed. little manual with lens not very informative.
I'd like to purchase a micro lens for my Nikon camera. My question is: Does the Phoenix AF 100mm f/3 5 Macro Telephoto Lens used with Nikon D 90''
If the Phoenix lens is autofocus (AF) in Nikon mount, it will work with the D90. You may find that you want to switch to manual focus when you are using it for macro shots for better control of focus. It will still set exposure properly when set to manual focus.
Apr 03, 2009 • Cameras
It wont focus or take pictue
Hey harleymomma,
If the d70 is set to AF-S mode focus has to be achieved for the shutter to be allowed to take the photo. In some exposure modes the aperture must be locked down on the smallest aperture. I would also make sure the contacts are clean that allow communication between the body and the lens. Of course you need to make sure the body and the lens are set to autofocus. If none of this works I would have it looked at by an authorized service technician. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Top Nikon Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Nikon Camera Expert? Answer questions, earn points and help others
