Question about Stanley Garden
Stanley P1800S pressure washer lost pressure after a few uses
  • Stanley Master
  • 2,010 Answers
The valve-o-rings + [ parbaks seals ] where the pressure can be adjusted with.
Control the water inlet filter or hose that there are no waterlock couplers are used or is mounted
on the wrong site on the hose , that it is used as water inlet on the tap.
Posted on Dec 25, 2016
SOURCE:
Stanley motorised pressure washer. Cant get the water to flow
Disconnect the wand from the washer if you get water coming out of the discharge, the problem is in your wand or the line is plugged going to the wand.
Feb 27, 2015 | Stanley Garden
Why is my Stanley TRE 500 locking up after stapling a short time. What is the + and - on top for? I have lost my manual.
Make sure you are using the right staples for it. This will prevent lockups. You can also try spraying the staple track with a dry silicone lubricant.
The Plus and Minus is to set the strike pressure. Low for cork board, high for oak paneling.
Here is the manual, the TRE550 is close enough.
Stanley TRE550 Electric Staple Brad Nail Gun
Sep 21, 2014 | Electric Stanley Tre500 Staple Gun /...
Stanley instruction manual
There is a spring in there that makes it recoil. It has probably broken. Depending on who made the engine you can get a replacement for the whole assembly. A small engine shop should be able to replace it for a not a lot of money.
Aug 14, 2014 | Stanley Gas Pressure Washer: 2750 psi 6.5...
P1800s-BB no water comes out of garden hose with coupler attached
Remove the fittings and check the internal screens, probably rusted and or clogged.
Jul 04, 2014 | Stanley 1800 PSI 1.4 GPM Electric Pressure...
Why won't my pressure washer start?
Im currious what on a pressure washer required "cleaning" what were you running thru it other than water ?
do you think you might have dissasembled something on engine part and might not have assembled it back quite right?
May 03, 2014 | Stanley 2350 PSI 2.3 GPM Gas Pressure...
Users Manual Download
Will any user manual serve, or do you have something more specific in mind?
May 01, 2013 | Garden
Leakage from the garden hose connection along with connection to the pressure washer.
The female hos bib connection should have a typical hose washer inside.Often you can't tighten the nut tight enough without this washer, to keep it from leaking both from the hose, and the rest fo the fitting into the washer.
Jun 14, 2010 | Stanley 1600PSI Pressure Washer w 20ft...
Does not **** up detergent with the attached slim line hose
It only picks up under low pressure condition eather by adjusting wand or changing tip.
Mar 18, 2009 | Garden
Garden Logo
116 people viewed this question
Top Stanley Garden Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
mpservices
Andrew Taylor
Andrew Taylor
Are you a Stanley Garden Expert? Answer questions, earn points and help others
