The motherboard accepts 2 GB unbuffered DDR400*/333/266/200 non-ECC DDR SDRAM Memory
*may run only at 333 MHz (DDR333)
You can download the specs at http://support.asus.com/download/download_item.aspx?product=1&model=A7V400-MX%20SE
Choose the English version.
You can use 184-pin DIMM, DDR PC3200 Memory Module
Specification:
Manufacturer
Asus
Manufacturer Part #
A7V400-MX
CPU Support
Socket Type
Socket A
CPUs Supported
AMD Athlon XP/ Thoroughbred/Barton
Front Side Bus Speed (FSB)
400/333/266/200 MHz
Form Factor
Micro ATX
Chipsets
VIA KM400A/VT8235 CE
BIOS
2Mb
Flash ROM, Award BIOS, TCAV, PnP, DMI2.0, WfM2.0, SM BIOS 2.3, ASUS EZ
Flash, CrashFree BIOS, ASUS C.O.P. (CPU Overheating Protection)
Memory
Number of Slots
2 x 184-Pin DIMM Sockets
Memory Type
DDR SDRAM
Maximum Memory
2 GB
IDE
2 x UltraDMA 133/100/66
Yes, it will work. Remember that all memory will operate at the speed of the slowest memory though so unless you're completely replacing the memory it won't increase the speed of the memory.
