Frigidaire stove model CFEF372EC3 Ser #NF60720192
Things to check : Thermostat, heating element and the circuit breaker for the stove at the power panel. If the stove has lights and the clock works, there is a 100 % chance the circuit breaker is at fault. There are 2 breakers with joined trip handles. One of those breakers has tripped without tripping the other which stops 20 volts but not 120 volts that the clock and light run off of. You can use a multimeter to check the element for continuity. If there is continuity then check for the presence of voltage at the element terminals. None indicates a bad thermostat.
