Question about Uniden Cordless Phone
Can you control the number of rings before going to voicemail on A460g one touch
Goes to voice main on first try on second try rings
According to iPhone faq.org: " How can set the number of rings on my iPhone before voicemail picks up?
You can set the iPhone to wait longer or shorter than the default 20 seconds before it goes to voicemail when receiving an incoming call. This will result in a different number of rings before the voice messaging system picks up the line and plays your outgoing message. To change the amount of time the iPhone will ring follow these steps:
1. Open the phone app and dial *#61# on the Keypad. Press the Call button.
2. Locate this text on the screen: "Setting Interrogation Succeeded, Voice Call Forwarding, When Unanswered, Forwards to +" and record the 11-digit number after the + symbol.
3. Touch the Dismiss button. Now enter this code on the Keypad: *61*+ followed by the 11-digit Forwards to number recorded in step 2, followed by *11 and *ringtime#. Ringtime is the number of seconds you want your iPhone to ring before voicemail picks up. Your finished code should look something like this:
*61*+18555513466*11*30#
In the example above the ring time is set to 30 seconds. Press the Call button.
4. You should receive the message: Setting Activation Succeeded. Press Dismiss and next time you receive a call it will ring for the new amount of time before going to voicemail."
According to Apple Tool Box.com: "having this problem, please try the followings:
  • Make sure that iPhone's Ring/Silent switch is OFF meaning ringer is ON. A bell will flash briefly on the screen when you turn on the ringer.
  • Make sure that the Do Not Disturb setting is not silencing calls (Settings > Do Not Disturb).
  • Make sure that Airplane Mode is OFF (Settings > Airplane Mode).
  • Make sure that your carrier software is up to date (Settings > General > About)."
    AccorA
Apr 15, 2015 | Apple iPhone 4S
Turn off voicemail 6408D+
Turning off voicemail is usually done by the voicemail administrator, they can reset passwords and add or delete a mailbox on an extension. The number of rings before going to voicemail is usually system wide, and that program is changed by whoever programs your phone system.
Apr 21, 2014 | Avaya Definity PBX Phone 6424D+ Gray
Voicemail number changed on samsung galaxy and can not check voicemail now
Voice mails are set up from the phone company. Your phone has no control over the voice mailing service other than assigning a speed dial to it. You should call your phone company on their customer service number and they will tell your the number to call for setting up your voice mail box.
Mar 11, 2014 | Cell Phones
On the uniden TRU9466 is there any way to increase the number of rings before it goes into voicemail?
The TRU9466 isn't an answering machine. The number of rings is controlled by whatever answering machine or voicemail system you have on your phone line. Please refer to the documentation for the answering machine or voicemail system to change the ring count.
If you need further assistance, please reply to this post and specify the answering machine or voicemail system.
Jan 22, 2014 | UNIDEN AMERICA CORP Uniden TRU 9466 -...
How to change the number of rings on my cordles telephone TRU9260 series
The ring count is controlled by the answering machine or voicemail system on your phone line. The TRU9260 is just a phone, it will ring until your or the answering machine/voicemail system picks up.
What answering machine/voicemail system do you have?
Oct 04, 2013 | Lands Phones
How to increase ring duration
First of all you need to know the number you dial for voicemail. Make a note of this.
Then, go to the dialpad and dial:
*#61#
and press Call.
A box will popup telling you what the redirect to voicemail delay is. On my handset the default was 15 seconds.
Now, dial:
**61******SECS#
and press Call
where *** is your voicemail number and SECS is the number of seconds you want it to ring for before diverting. For example, on Vodafone UK the voicemail number is 121 so to set the ring for 30 seconds before diverting, dial:
**61*121**30#
Once the box has come up saying it was successful you can use *#61# again to check the setting.
Oct 27, 2011 | HTC HD7 Cell Phone
How do i change the number of rings before voicemail picks up on a samsung rugby
For all of you that want a real answer here ya go. This isn't something you can change on your phone this has to be changed with your service provider. If you are with AT&T, like I am, then this is the solution for you (link of where I found it below as well). 1. enter *#61*11# and press send/talk on your phone.
2. write down the number your calls are currently forwarded to (usually +1401#######, but not always). this is your voicemail deposit number.
3. decide how long you want the phone to ring in 5 second intervals. the maximum time is 30 seconds. i'd recommend 25 seconds or less, as using 30 may cause you to be billed for a minute of airtime each time someone is forwarded to voicemail.
4. now enter **61*[number from step 2]*11*[number from step 3, use 2 digits]# and press send/talk.
example
voicemail deposit number is +14015551212
you want it to ring for 20 seconds
you would enter **61*+14015551212*11*20# and press send/talk.
if you have trouble with the above procedure, you can always call customer care at 800-331-0500 to change it.
OR QUESTION: How can I adjust the number of times my wireless phone will ring before the caller goes to voicemail? ANSWER: Contact Customer Care at 1-800-331-0500 or dial 611 from your wireless phone to change the amount of time your phone will ring before going to voice mail. The adjustments made by Customer Care are based on the traditional ring heard by the caller, not the unique Ringtone you hear from your phone. I just wanted to add that increasing the ring length to 30 seconds will not cause you to be charged a minute should the caller go to voicemail. This was confirmed by an AT&T technician.
http://forums.att.com/t5/Voice-Mail/Increase-the-number-of-rings-before-a-call-goes-to-the-voicemail/td-p/2576651
Aug 11, 2011 | Cell Phones
My phone on our Norstar system rings & rings & never goes to voicemail. Other sets on this system ring 4 times & then automatically go to voicemail. How do I cjange my set?
Fress F985 u will get voicemail DN. Note down ur voice mail DN.
Go to programming of Norstar which will be F**266344 password will be 266344.
Dispaly shows u terminal and extensions.
press show
then next display will show u capabilities.
Press show then next display will show u FWD no answer.Press show then change put the voicemail Dn which u had written then next.
Now call will go to ur voicemail provided u have ur own presonal mailbox. If it is not there u will have to createe it otherwise it will go to general delivery mailbox.
Hope it will be helpful for u.
Thanks.
May 08, 2009 | NorStar Startalk Flash 2 Phone
Fax answers on phone calls.
Hello There. Most household all in one units cannot operate on the ring characteristcs that you are describing.
They simply operate on the number of rings before automatic pickup to the fax machine. Therefore, you will need to just change the number of rings before the fax machine picks up. In this case however, you will not be able to use voicemail, since one or the other will will pickup.
http://h10032.www1.hp.com/ctg/Manual/c01102249.pdf
Page 63 and 64 (in PDF) or page 62 and 63 (hardcopy manual) explain the process.
Ignore the information about setting higher then voicemail. That information is typically only valid if you have the old voicemail devices in your home. Most people now adays get a voicemail service added to your telephone service, in which case you cannot control the voicemail as easily.
So again, in other words you will be sacrificing your voicemail for your fax machine. Only other way around it is to get a dedicated fax line to seperate the two numbers.
Feb 26, 2009 | HP Photosmart C6180 All-In-One InkJet...
Uniden Cordless Phone Logo
153 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
