Disney DT1350-P 13" TV Logo
Posted on Nov 20, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
TOSHIBA 32 CE32T11
BOUGHT TV USED AND CANNOT TAKE OFF PARENTAL CONTROL
Anonymous
Level 2:
Sergeant:
Champion:
  • Expert 298 Answers
  • Posted on Nov 20, 2007
Anonymous
Expert
Level 2:
Sergeant:
Champion:
Answers
298
Questions
Helped
104153
Points
809
If you have the remote for the set
you can reset the TV to factory
settings
while in the pin code entering
mode , press the recall button
4 times within 5 secondsThe
pin code will be
released (reset)
2answers
I need a pin code for a Toshiba tv. Please
hi Cheryl.
Press the "MENU" button, select Prefer, highlight Parental Control and press the right arrow key or menu button to enter the PIN code entry screen. 0000 is the default password. When the correct PIN # is entered the Parental Control Menu opens and you can change your settings and PIN code here.
Changing the TV password
or read up some more at this manual.
Toshiba 19L4200U User Manual Forgotten Pin Code Changing Or Deleting Your...
or this one.
4 digit pin code for toshiba tv Google Search
Tosh1ba 32" Telev1s1on model #CE32T11 has a vert1cal l1ne all the way across telev1s1on
Something fault with horizontal sweep out section circuit. If you are not familiar with electronics, do not attempt to repair. Whether you suffer fatal electrical shock! Instead, contact any experienced service technician, or the nearest service center
1helpful
My sony that i bought used has a parental block. dont know the code. no remote!!
You will need a universal remote, however, the master password is 4357. After the master password, you must create a new password, it cannot be used to unlock currenly blocked channels.
Thanks
J
Hi my toshiba28z23b tv says front panel locked how can unlock the front panel
Go into your user menu and then to setting or parental control. You should see an option to lock and unlock your panel.
Just bought a used older model rca tv parental controls locked. any master codes to bypass parental control
If you forget your password, press and hold TV on the remote and the
MENU button on the television
simultaneously for 3 seconds. Parental
controls will then unlock and you can re-enter a password via Lock
Parental Controls.
Make sure you aim the remote at the TVs sensor while you press the TV button, and hold the menu button in on the front of the television.
2helpful
2helpful
2answers
Reset Parental Control
Good day.
Try to press power up button, channel up and volume minus at the same time. This should resolve your problem.
chris
Quasar TV access code for parental control
same problem as discribed on a Quasar sp2722 0000 didnot unlock the parental control
thanks
3helpful
2answers
Unable to change v-chip code in my sharp television set HELP
Go to Sharp webste http://www.sharpusa.com/ download your manual for the tv and whala it is done...
APEX 32" FLAT PF3220 PARENTAL CONTROL
You can try but, I bet the original remote is needed for this operation.
Top Disney Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
Alexander
Are you a Disney Televison and Video Expert? Answer questions, earn points and help others
