Run an alignment page. This will show you if it's the same nozzle(s) every time. Sometimes an alignment error can cause a multi-color print to appear blurry.
If you have alternating broad strips of sharp and blurred printing, something such as an out-of-round roller may be causing the paper to head distance to vary.
Make sure there is no dust or lint buildup on the ends of the head slide or in the head parking area (outside the paper margins) to smear ink on the heads. If that's clean, the nozzle valves may be leaking, which means a head replacement is the fix. (Another thought: if this is one of the models with separate ink tanks, you may be able to put some rubbing alcohol in an empty tank and print a solid color page or run a cleaning cycle with that in an attempt to "deep clean" the head. No guarantees, of course; it may even make the problem worse, and is a last-resort means to avoid buying new heads.)
Fix Epson Workforce WF-3640 blurry printing issue:
So, if you are dealing with Epson wf-3640 blurry printing problem, then go through some easy and effective solutions to fix this problem without any hassle. If you Need Instant Help The Dial our Epson printer troubleshooting number 817 442 6637 or you can follow these steps:
Solution 1- Adjust the resolution
As we mentioned earlier, if the resolution of the image you want to print is low, this could be a valid reason for this error to occur on your system. The resolution contains digital information about the image.
So, if you wish to download a lower resolution image, we suggest that you adjust the resolution of the image and then try to print it.
If done, the job is done, otherwise move on to the next solution.
Solution 2- Enlarge small images
You may get an option 'If you want to save the image on your computer and print it in a set size like 8×10-inch, in that case, the size of the image is 3*4 inches. It simply means that you cannot print images.
As a result, you may face Epson wf-3640 blurry printing issue on your system. In this case, you will need to print the images in their original format to resolve the issue.
Solution 3- Quality Settings
If you have already applied the above two solutions and none of them worked for you, we recommend you to check quality settings of Epson printer.
You know that Epson printers give you a variety of quality settings, from draft to best quality. Thus, you should make use of the best quality of services.
If you want to print an image within a paper, you can use Draft Quality. If you fail to configure the quality settings in this way, this issue may haunt you.
So, in this case, you have to set the quality settings properly and after that check if the problem is resolved or not.
If you fail to solve this time also, then move on to the next solution.
Solution 4- Ink Alignment
If the resolution and quality, everything is fine, then there must be something wrong with the ink alignment.
Sometimes, the tubes that release the ink get clogged and as a result, you may face this problem on your system.
Epson printers have an inbuilt feature that can help you troubleshoot the problem. So, all you have to do is follow the instructions and apply it on your computer.
After this, you may no longer encounter this error on Epson printers.
parting words
Hopefully, the above mentioned solutions will help to fix this Epson error on its own. However, all these processes are a bit complicated and require technical knowledge.
So, if you don't have that much knowledge, we suggest you don't waste your precious time and trust an expert to get rid of blurry printing problem permanently.
