The TCON board or the LCD panel is faulty. Can confirm by replacing the TCON board.
If you wish to get some details about TCON board problems ; check the site linked here. http://electro-medical.blogspot.com/
? 10:21
https://www.youtube.com/watch?v=CpWZTnAXbLg
Dec 30, 2013 - Uploaded by Pet Rock's Garage
This video covers how to fix a Panasonic 42" Plasma TV model TH-42PX600U that has vertical distorted ...
Clean the glass on the extreme left side of the printer. Lift up the feed tray and clean the vertical glass. You probably have some debris on it, such as white out or some other stuff.
You have A buffer board out if the line goes up and down then its the long board going left from right look were the line is and see what board the line lines up on the screen and replace that one
these boards are the closet to the edge of the tv
same process if the line goes across the screen
look for the part number on the board and search with google or go to shopjimmys.com and seach there or call them
Honestly you have a big problem because the driver IC & Tape Carrier Package inside controller board at vertical area are damage or itself defective could cause you have 2 inches line appear in your display. The best solutions for this replace lcd panel to fix vertical line.
Black lines are usually a sign that you have toner on the laser slip glass which is usually situated above the drum unit, its just a little bit of glass if u give this a wipe and get toner on ur finger or rag then thats probably what wrong. If you don't I would look at your drum unit as it might not be cleaning correctly, which would mean getting a new one.
Hope you find this info helpful.
Cheers
