check you have set to the correct year, and remember a leap year has one day more... note date,month stays the same but the day changes from year to year.. hope your clock has a year function?
To reset the time on the Seiko QHR021S proceed as follows:
Press and hold the "Reset" button on the back of the Seiko QHR021S with the tip of a pen until the "Seconds" hand starts to move rapidly.
The "Seconds" hand should stop at "12". Then the "Minutes" & "Hours" should also work their way round to "12".
Give it a few minutes until it picks up and synchronises with the radio time signal and the clock should then adjust itself to the correct time.
Remove the battery cover, press and hold set until it beeps. Use the up down keys on the front and you cycle through year, month/day, then time, then 12/24 hour mode. You advance to each function using the set key. Once through the cycle, the time will stop flashing and the clock will function normally.
The time should be done on automatic by pressing WAVE.
To set manually: Press the [SET] Button for more than 2 sec. The Year will pop up set to correct year then press SET again to set date/mth, keep holding till it get to right month n date (the month and date does not set separately). Press SET again and set TIME then press SET again for your choice of 12hr or 24hr.
