Can't find any paper in the printer, but when trying to do a status report the paper isn't picked up & feed into the printer.
SOURCE: keep getting paper jam error message for hp office jet 6210 all in one
check the skew parameters
SOURCE: Paper jam in HP 4255 office jet all in one printer
Clearing paper jams
Paper jams can be real or false. The unit may report a paper jam even when there is no jammed paper. The solution to a real paper jam or a false paper jam is the same.
CAUTION:
Jammed paper must be removed using the rear access door with the power cord disconnected to avoid mechanical damage. Do not remove jammed paper from the front of the unit.
Figure 2: Removing the rear access door
Preventing paper jams
The following information will help prevent paper jams from occurring:
SOURCE: HP Desk Jet 3320 paper won't feed any more
Hi , I think the belt which moves the cartridge is worn out or it could be something to do with the sensor.check both and should work fine.
SOURCE: error 13.10 paer jam in HP laser jet 5100 DTN
HI ayyasamyr:
This your problem.
13.10 PAPER JAM The event log message for a paper-delay jam in the duplexer is 13.10.
1. Check the duplexer and the rear area of the printer for obstructions or damage.
2. Check PS1701 and PS1703 in the duplexer for correct operation. Replace the
duplexer if a sensor is defective.
Hope this helps
SOURCE: HP deskjet F380 - 'status: paper jam'. There is no paper jam!
Unplug the power cord and while doing that make sure printer is powered on i mean do not turn off the printer using the power button. When you unplug the power cord than press and hold the power button for 30 seconds. Than release the power button and connect the power cord and then try to print.
