Health & Beauty Logo
R
Robert reid Posted on Dec 20, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Scooter just beeps but won't move - Health & Beauty
NOEL
Level 3:
Top Expert:
  • Health & Beauty Master 8,606 Answers
  • Posted on Dec 20, 2016
NOEL
Level 3:
Top Expert:
Answers
8606
Questions
18
Helped
2322063
Points
68630
Freerider Mayfair-S Mobility Scooter continually beeping after changing tyre.
Question edited for clarity.
Question moved from MISC to a Freereider category.
Somewhere at the Freewheel there must be a switch and it isn't registering that Freewheel is disengaged.
Here is the parts diagram, but it gives no clues. You could phone them?
https://www.freeridernetwork.co.uk/wp-content/uploads/2014/05/Mayfair.pdf
2helpful
2answers
TGA VITA S constantly beeping but moves
hi Ruben,, if it sounds like the horn button is pressed maybe not that loud , then you got water in the horn button that is conducting , carefully take a hairdryer and warm the button etc and I mean warm not hot!, remember its plastic ..
if it's a beep pause beep and so on, it the scooter telling you the batteries are low ...
regards
Rob
What do the beeps mean?
  1. Popular Drive Medical Ventura 4 Wheel Deluxe Scooter ...
    www.fixya.com > Forum > Mobility Scooters > Drive Medical
    Popular Drive Medical Ventura 4 Wheel Deluxe Scooter ventura418cs Power Mobili ...My Go Go Elite Traveller mobilty soccer beeps when I try to go Forward.
2answers
Scooter won't move when forward/reverse engaged.
http://mobility123.com/help-fix-mobility-scooter-powerchair/
Engage the freewheel lever
- allows you to operate the mobility equipment with the standard controls.
Disengage the freewheel lever - This unlocks the unit and allows the wheels to spin freely. You can easy push the equipment without power. This is especially helpful if you run out of battery power and need assistance.
2helpful
2answers
How to stop a continuing beep on my Cordoba scooter when I turn the key on? The scooter don't move at all.
Hi Mag,
I have this steps that might help you with beeping sound on your Scooter. Hope it helps.
UNIT LIGHTS UP/HORN WORKS BUT UNIT WILL NOT MOVE
Possible Cause:
  • This often occurs when the scooter is in free wheel mode and is not in drive mode. Re-Engage the free wheel lever which is located down near the rear wheels (normally a yellow or red lever).
  • If you hear a beeping noise, the beeping you hear is a fault beep indicating the scooter main control box has detected a problem. Contact your dealer who can diagnose the beep code.
  • Check batteries with load tester - If either battery drops more than 1 volt under a load, the battery(s) are bad. Replace "both" batteries.
I also find these additional steps on how to know beep alarm indicators:
This main control box has a self-diagnostics feature & cannot be tested with a volt meter. When a
problem is present the main control box will diagnose the fault, prohibit the scooter from being driven
and sound an alert beep. Each alert beep indicates a different issue which helps to determining the
problem by narrowing the fault into one of a few main areas of the scooter. Reference this information
below for the alert beep indications.
Very Rapid beep- Batteries are low. Charge & test batteries.
Medium Fast beep- Motor/brake wiring fault. Free wheel lever disengaged.
Solid beep- The charger is plugged into the scooter (some models may vary).
Very Slow beep- The throttle pot was not at center when you turned the unit on. Throttle pot off
center or wiring (yellow & orange wires) fault.
1helpful
2answers
Battery shows fully charged and the horn beeps but it won't move.
I have the same problem in mine.. But the beep is continous. Mine is a fortress 2000 AT. anybody knows what's the trouble on this one?
1helpful
In Drive position the wheels are locked and in neutral the wheels remain locked and will not spin or free wheel. In drive with the battery in the unit just clicks but does not move, everything works such...
I would suspect that the brake is not releasing causing your problem. When you place the handle in freewheel and you can't push the scooter easily then the brake pad is stuck on the motor housing. If you are able remove the seat and back cover remove the drive wheel on the side of the scooter nearest the freewheel lever usually the right side. you should be able to see the brake attached to the end of the motor with 3 or 4 hex head screws. take the brake off the end of the motor and carefully leave the wiring attached ( don't break or remove the wires going to the brake or the scooter will not run at all) remove the brake and place or tie it up where it won't fall or drag. Put the drive wheel back on and turn the scooter on and see if it will now move. If it moves like it should you will have to replace the brake. You can drive the scooter like this but remember you do not have brakes so the scooter can roll backwards or forward when not on and especially on ramps Hope this helps
Top Health & Beauty Experts
Rob Hill
Rob Hill
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Health and Beauty Expert? Answer questions, earn points and help others
