1- Royal Coffee is not an accurate model. I have to assume that you are having problem with the auto frother that is on the left side of the machine. The auto frother draws milk from the bottle and steams it into the cup.
2- The connection of the frother & the adapter is not right/air tight. The two O-rings on the frother must be pushed in all the way so the O-ring will not be visible.
3- The frother circular chamber for steaming is not clean. There should be no milk deposits visible at all.
4- The silicone tube puling milk from the bottle is connected to the body of the frother with an L-shaped connector. Make sure this connector is air tight fit.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edward_bbd2c7ff4ee1828a
There is probably something wrong with the milk frother. I would purchase a new one before having the machine serviced.
http://cerinicoffee.com/cappunicatore_Royal_white.asp
