Over run with Indian minors traps don't work
SOURCE: Daisy Red Ryder BB gun won't shoot
1) **** the gun and look through the hole in the top, half way down the barrel.
2) You should see a BB loaded into this area.
- if no bb is present and you can see a circular magnet, then it is not loading.
3) if the bb is present and does not exit the barrel when you fire the gun, then the bb is deformed and will require the rifle to be dissasembled and rodded through the back side, forcing the bad bb out of the way.
4) If no bb or magnet is present through the hole, call daisy for a replacement. This indicates the shot tube has moved and will no longer load.
SOURCE: My Thermal Dynamic Drag Gun
Hi:
There is no mention of the Thermal Dynamic's gun model, but i will suppose that it is a SL60 or a SL100 which are replacement guns for any model of plasma using the proper adaptor.
Your problem could be the start cartridge which go bad now and then when the gun is used as a replacement of a hammer to make the cut piece to fall.
The way to check if your start cartridge is in good condition is by checking the low part of the cartridge, push it up (or down depending on the way you handle it) it should freely slide inside and return out.
Good luck.
SOURCE: daisy, model 880,pellet/bb air gun maintenance manual
Here is the manual: http://daisy.com/_manuals/880_web_manual.pdf
SOURCE: do you have the rebuild kit a powerline 990 daisy dual power bb gun
You can buy o ring cord and make your own
Www.gunmanualsonlie.com
