Jimmy Mangrum Posted on Dec 20, 2016
My jbl reflect mini wont charge and i cant get the light to come on at all
JBL charge 4 only powers on if plugged into wall..
It sounds like the internal battery has failed. Try and claim on the warranty or ask for a repair.
JBL Support - Returns & Warranty
JBL https://ca.jbl.com > support-returns-and-warranty
If you believe your product is malfunctioning during the warranty period, we can help!
Warranty
JBL https://ca.jbl.com > warranty
Unless a different warranty period is stated in the Warranty Card provided with your JBL product, JBL warrants for a period of 1 year (5 years for any non- ...
Troubleshooting help
https://www.ifixit.com/Wiki/JBL_Charge_4_Troubleshooting
JBL Charge 4 TroubleshootingiFixithttps://www.ifixit.com > Wiki > JBL_Charge_4_Troub...Make sure the charging light on the base of the device is blinking. If it is fully charged and still not turning on, the power button may be worn out or broken. ‎The Speaker Will Not Power... · ‎The Device Won't Connect to.....
Jbl reflect mini bt not tuining on
If you wish to get some details; check the site linked here. Pull up older posts.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
How do you charge them
The JBL logo on the right earbud has a little hinge you can open and plug in any micro usb charger.
My JBL CHARE wont charge it will only flash a red light
I assume you mean a JBL Charge. As for that specific model I am unfamiliar, however if when you try to charge electronics they will only flash a red light that's usually a battery or charger error signal. Most likely either a battery in the battery pack has gone bad, a contact has come loose or your charger has broken. Did you happen to drop it shortly before this error occurred? Also was the battery completely dead right before this happened? Sometimes I have noticed wireless devices will refuse to charge a battery if it is completely drained.
Jbl instructions
Took about 3 seconds on Google, including typing in the product name. These things are not difficult. You should try it. JBL OnBeat MINI Black JBL
JBL FLIP STOP WORKING
I suspect that the power supply you are using has dies. Do you have access to a similar one or can you obtain a new one? I think that is all you need.
Top JBL Audio Players & Recorders Experts
 Grubhead
Grubhead
Bob Kirkwood
ADMIN Andrew
ADMIN Andrew
Are you a JBL Audio Player and Recorder Expert? Answer questions, earn points and help others
