SOURCE: No sound from digital cable thru AVR3200 after adding HDTV - DVD plays fine
you need a digital coax cable and then connect it to 6.1 also the digital cable type is not a coomon type so check that also
SOURCE: no picture, only sounds when playing DVD
The issue might be that you could be missing some codes to play the dvds.
First i want to uninstall all the codecs from the control panel - add/remove programs.
Then download the latest vesion of klite codec pack with the player.
The link is :
http://ftp.freenet.de/pub/filepilot/windows/multimedia/video/k-lite_codec_pack/klcodec390f.exe
Install this by selecting "lots of stuff" with the player.
Then play your DVD, it will work fine.
Good Luck.
Live, Love, Laugh.
Have you try installing the driver for your pc?
the sound driver and the
DVD software need to be installed
SOURCE: No sound watching dvd clips in Cyberlink DVD Suite
http://www.videolan.org/vlc/download-windows.html
Download VLC player and play your DVDs or CD which one not giving you sound...if its working with VLC and your problem solved then download Divx, and Xvid codec...and intall its and try to play same DVDs on Cyberlink DVD.....Please let me know if problem solved...
SOURCE: go video VR4940 VCR video recording has sound but no picture
You can try cleaning the video tape heads. The vcr has 2 different heads. One for audio which is fixed and a drum head for video with 2 heads on it that rotate. The best way to clean them is to take a lint free cloth ad wrap it tightly around your finger. Put some alcohol on the cloth and place it on the drum. Then rotate the drum as you hold your finger against the drum. DO NOT move your finger up and down as you can brake the head off. The other option is to go buy a head cleaning stick. It's a piece of chamie on a plastic tongue depressor. I've cleaned hundreds of them with my finger though. You can clean the whole tape path with the rag. Good Luck.
