Mercury Villager 99 1999 Logo
Rhonda's Wisdom Posted on Dec 16, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Where is the vaccum advance located on the 1999 mercury villager
Marvin
Level 3:
Top Expert:
  • Mercury Master 85,242 Answers
  • Posted on Dec 16, 2016
Marvin
Mercury Master
Level 3:
Top Expert:
Answers
85242
Questions
28
Helped
29036940
Points
266281
This engine doesn't have any such part, the ignition system is fully computer controlled. Vacuum advances went away with the advent of computers.
2000 Mercury Villager. Where is cruise control fuse please?
There isn't one. Cruise Control is a joint computer operation by the BCM and ECM.
Mercury Villager (1999-2002) fuses and relays
Fuse Box Diagrams https://fuse-box.info > mercury > mercury-villager-19...
Here you will find fuse box diagrams of Mercury Villager 1999, 2000, 2001 and 2002, get information about the location of the fuse panels inside the car, ...
https://www.google.com/search?q=mobile+auto+electrician+near+me
How do i fix my Mercury Villager 2002 with random misfire?
How to Fix error code P0300 for random misfires on your car ...
diy-auto-repair.wonderhowto.com/.../fix-error-code-p0300-for-random-...
Oct 15, 2010 - How to Fix error code P0300 for random misfires on your car ... amisfire (code P0304) on a 1999 Mercury Villager 3.3L · How to Fix error code P0500 ... I reset my codes and it ran fine for a couple of days, then I started getting ...
(code P0305) on a 1999 Mercury Villager 3.3L - auto repair
diy-auto-repair.wonderhowto.com/.../troubleshoot-misfire-code-p0305-1...
Sep 7, 2010 - The vehicle is a '99 Mercury Village, 3.3L, with 150000 miles on it. The chief ... How to Fix error code P0300 for random misfires on your car ...
2000 Villager Misfire - Car Forums and Automotive Chat ...
www.automotiveforums.com > ... > Mercury > Villager
May 24, 2010 - 2000 Villager Misfire Villager Car Forums. ... i was told that the 3.3L engines of 1999-2002 nissan quests/ mercury villagers are INTERFERENCE engines! ... Hope the following may help, and I will post if my last fix works. ... I have a 1999mercury villager that is showing a random multiple cylinder misfire ...
Rough Idle - 2000 Mercury Villager - RepairPal
repairpal.com > Questions > Mercury > Villager > 2000 Mercury Villager
Repair the code issue, because your Villager has OBD-II which is a very helpful Diagnostic system. Upvote (4) ... My 1999 Villager was running poorly; rough idle, lack of power at highway speeds and the engine problem light indicated random miss-fire, etc. I had new spark ... Have code po306 cylinder 6 misfire detected.
P0301 - OBD-II Trouble Code - RepairPal
Why does idle remain high on 1999 mercury villager
A stuck idle speed control motor ! Tap it with a wrench or something similar , You'll find it located on the throttle body ! Ford IAC valve test how to adjust minimum idle speed
We recently replaced the engine in my 1999 Mercury Village minivan. Now the wipers won't work when the engine is on Where is the wiper relay located or what could be the problem>?
The wiper governor is in the enigne comaprtment, driver side. You probably have a bad ground in the engine compartment casuing this issue from the engine swap.
1helpful
We are trying to replace the electronic flasher relay in our 1999 Mercury Villager. Can you tell us where it is located?
The electronic flasher relay is located below the interior fuse block (Next to the hood release handle)
Where is the automatic transmission computer located on a 1999 mercury villager?
The computer is not separate, it is the main system computer. Unless you have tons of money, get your vehicle diagnosed by a qualified shop. Computers are expensive.
Where is the flasher located in a 1999 Mercury Villager>
1999 Mercury Truck Villager Wagon 3.3L SFI SOHC 6cyl
Flashers
The turn signal/hazard lamp flasher is located behind the driver's side of the instrument panel to the right of the steering column.
REPLACEMENT
  1. Disconnect the negative battery cable.
  2. Locate the flasher assembly under the driver's side of the instrument panel. Press the tab on the flasher and slide it from the bracket.
  3. Detach the flasher from the electrical connector and remove the flasher from the vehicle.
  4. The installation is the reverse of the removal.
Hope help with this (remember rated and comment this).
1helpful
Fuel temperature/sensor
go here for villager help http://autos.groups.yahoo.com/group/villagerquest/ SECTION 303-14: Electronic Engine Controls 1999 Villager Workshop Manual REMOVAL AND INSTALLATION ------------------------------------------------- It's in the fuel tank. WHy do you think you need to replace it? They seldom go bad. Fuel Temperature Sensor Removal Remove the fuel pump; refer to Section 310-01 . Remove the fuel temperature sensor. Disconnect the electrical connector. Disconnect and remove the fuel temperature sensor from the clip.
1helpful
3answers
1999 MERCURY VILLAGER fuel pump location
The mechanical fuel pump is located on the engine block or on the cylinder head.
G
Top Mercury Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you a Mercury Car Audio and Video Expert? Answer questions, earn points and help others
