SOURCE: Generac portable generator doesn't produce power
Remove front cover on the genset and you will see the brushes and rings. Clean the rings if black with emory cloth and inspect brushes. Flash the fields by apply a 12V battery to the brushes. the brush closest to you or the bearing is connected to the positive side of battery and the back brush is negative. You have to do this with genset running. You should notice your voltage climb up to over 50Vac maybe even over 100Vac. Make sure to use rubber gloves when flashing fields and keep hands away from rotating parts. if voltage does increase when flashing the the voltage regulator is shot. If voltage does not climb then you will need a new genset or generator end.
SOURCE: portable generator head stopped making power
portable generator head stoped making power engine runs fine sircut brakers are fine
No electrical
output
1. Faulty receptacle. 1. Have Service Center
replace.
2. Circuit breaker kicked out. 2. Depress and reset.
3. Defective capacitor. 3. Have Service Center
replace capacitor.
4. Faulty power cord. 4. Repair or replace cord.
5. GFCI switch breaker kicked
out (if equipped)
5. Depress and reset
