Question about Canon PowerShot Cameras
How to replace date/time battery in a canon powershot A1100IS?
Have a 510 and it is in a holder in battery compartment, not so with the a1100is.
SOURCE:
t00nz
  • 4738 Answers
SOURCE: upload canon a1100is to pc problem
First try uninstalling and reinstalling Zoombrowser. If that doesn't help, it's very hard to troubleshoot software problems online. But why put up with the headaches of bad software in the first place? Please see the following blog article, as it describes the use of a card reader as a much easier, faster, and less error prone way to download your photos. In fact there are several important reasons discussed in the article for using a card reader vice downloading from the camera. USB Card readers are also very inexpensive these day, with cost virtually not an issue:
http://camerarepair.blogspot.com/2009/01/how-do-i-download-photos-or-pictures.html
Posted on May 17, 2009
  • 11967 Answers
SOURCE: PowerShot A1100IS I cannot download pics,
Use a card reader to download your pics to a folder you create on your desktop.
Posted on Dec 15, 2009
  • 691 Answers
SOURCE: need software to put on computer to download
have you a card reader, transfer of files is usually quicker
Can you not just plug it in via usb lead and it recognise it as a camera?
try here if you need drivers etc. Remember to select your operating system at the top of the list:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=145&modelid=16347#DownloadDetailAct
Posted on Jan 15, 2010
Testimonial: "Thanks for the quick response I do not have a card reader there was a disk it seems when I purchased the camera but it seems to have walked off now. "
  • 11967 Answers
SOURCE: my canon powershot a1100is says lens error restart
That just means to turn it off and then on again. Try these for "lens error"... Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on May 11, 2010
SOURCE: How do you unlock the card on a Canon Powershot
Pull the sd card out and look on the left side with the card facing you. You will see a slide switch on the left side. It is probably in the down position (locked). Move the switch up and the card will be unlocked. Done!
Posted on Sep 06, 2010
Testimonial: "Simple question, simple answer. Thanks!"
Need operating instructions for Canon Power Shot A1100IS
Try Googling (canon)(A1100IS)(manual) without parens.
Aug 15, 2017 | Canon Cameras
Canon a1100is camera battery door replacement
Kurt- I have successfully completed a d-i-y battery door replacement on my Canon A1100IS, and I make no claims about being an "expert." My training was watching u-tube videos of guys disassembling digital cameras (other models). Here's how to open the case on the A1100is, which is not really much different than opening the case on most any compact digital camera.
Using a size #0000 phillips screwdriver (Sears sells a set of 6 minis--slotted and phillips--for $10), I removed the nine screws from the side and bottom of the case plus one inside the mini-usb cover and the one inside the battery compartment.
Then, I gently worked the front and rear of the case apart (the top of the case halves have two snap clips that hold them together. Unlike some cameras, the A1100IS does not have any flexible cable straps between its front and rear covers.
With the case halves removed, I then used a tweezers to move the straight end of the hinge spring out of its original place next to the tripod socket. That released spring pressure on the hinge and I could then easily remove the hinge pin with the tweezers.
Then, it's simply a matter of placing the replacement door's hinge/spring combo in the proper location and inserting the hinge pin to hold it there. I purchased a new door from Canon for $8.42 plus shipping). Then, I used the tweezers to position the straight hinge spring end in the slot next to the tripod socket.
The only thing left was to wipe my fingerprints off of the LCD screen and then gently replace the front and rear case halves--snapping the case's top together and then replacing the nine screws.
Feb 26, 2012 | Canon PowerShot A1100IS 12.1 MP Digital...
How do you replace the door on a Canon PowerShot A1100IS?
Take it to a camera or electronics store that does service work. They should be able to order the replacement parts and let you know if it is financially better to repair or replace the camera.
Jul 30, 2011 | Cameras
Powershot a1100is camera card is locked! How do I unlock it?
do u mean sd card then theres this like swich thing just move that to the way that you can
Jul 22, 2011 | Canon Cameras
I have a Canon powershot A1100is dig camera. When I try to turn it on, it reads need new batteries. even if I change the batteries. Sometimes it wont even turn on. Help
Do you using Ni-MH batteries? Canon cameras judge the battery is low power by the real-time voltage of the batteries. And the voltage of Ni-MH batteries are lower than Li-ion ones, so the camera will notice low power even there are new batteries. Try Li-ion ones and see is anything help. best wishes!!
If you will use of a special battery, please come to our online shop for digital camera batteries
Feb 21, 2011 | Canon PowerShot A1100 IS Digital Camera
How do you restart the canon A1100
http://www.freeservicemanual.co.cc/canon-powershot-a1100-user-manual/
canonpowershota1100.com/wp.../canon-powershot-a1100is-manual.pdf
This info is all in the user manual, so I have found one for you for later reference. Please simply download from the link above....
in any event the best way to restart is to Power OFF & then ON again, this will reset all settings and restart the software again.
Feb 13, 2011 | Canon PowerShot A1100 IS Digital Camera
I have a canon A1100IS and the LCD screen will not come on. Any suggestions would be appreciated. Thanks.
Try this.
1. turn it off
2. remove the batteries and memory card
3. reinstall new batteries and the memory card
4. turn it on.
If this doesnt work it will need servecing/repair.
May 30, 2010 | Canon PowerShot A1100 IS Digital Camera
Upload canon a1100is to pc problem
May 17, 2009 | Canon Cameras
Cameras Logo
276 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
Ekse
Are you a Canon Camera Expert? Answer questions, earn points and help others
