If you are convinced you did not switch the camera to manual settings, and the blur stays, please contact the nearest Canon certified service centre close to you. But before check the settings on the camera and start putting it on automatic.
One of a few things might be happening 1. Photos being taken at high zoom (i.e. 200mm) are susceptible to camera shake, even though the lens is focusing properly. The solution here is use a tripod, zoom out, or steady yourself. 2. Photos being taken without flash when flash should really be used will result in motion blur (which is slightly different than camera shake). This is due to the camera using a longer shutter speed to let more light in, with the side effect being that objects will move while the shutter is open, blurring the picture. The solution here is to use a flash, or take pictures in better light. 3. The camera may be focusing on something other than what you intended. 3. If you are taking photos in good light with a steady hand, and the camera is choosing the correct subject to focus on, then yes, the lens could need readjusted, though this is not a very likely scenario. If the lens is "hunting" for focus, that could be a sign that something is amiss. A local camera shop can verify the accuracy of focus for your lens.
Blurred images are caused by several reasons: motion due to camera shake, use of slow shutter speeds and failure of the camera to focus correctly.
Slow shutter speeds
When light is low, wide apertures and slow shutter speeds will be selected automatically by the camera. Most people can't take blur-free, hand-held shots when the shutter speed is under 1/60th of a second.
Cameras that have optical Image Stabilization help but even IS has its limits. Increase room lighting, increase the ISO setting or use a tripod, or use a combination of all three.
Blurred images or misfocus
If an image is blurred due to camera shake, the blur will appear throughout the entire image. If parts of an image are in focus, and others are not, you've misfocused.
There are three main reasons photos don't come out clear.
The first is focus. If your photo has something in the near foreground and something in the distant background, you may not get both in focus. This is not as much of a problem with compact point&shoot cameras simply because their field of focus is so deep. The second cause is subject motion. If you take a photo of a moving object, that object may blur. This is the case if moving objects blur but still objects do not. The third and main cause is camera motion. If you suspect this, try placing the camera on a table or other stable surface, use the self-timer, and take a photo. Compare this photo with one you take holding the camera.
If the camera is showing a black or distorted screen when set to photo, and photos that are taken with the black screen also show up black or distorted, then this would likely be a CCD imager failure, a common occurrence for your model camera. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status.Please check this linkfor more info.
There are three main reasons photos don't come out clear. The first is focus. If your photo has something in the near foreground and something in the distant background, you may not get both in focus. This is not as much of a problem with compact point&shoot cameras simply because their field of focus is so deep. The second cause is subject motion. If you take a photo of a moving object, that object may blur. This is the case if moving objects blur but still objects do not. The third and main cause is camera motion. If you suspect this, try placing the camera on a table or other stable surface, use the self-timer, and take a photo. Compare this photo with one you take holding the camera.
It may be that the infra red sensor needs cleaning or is covered with something like fluff or grease from sun cream. This would prevent it seeing clearly in lower light conditions.
The following exposure options are available: P (Program auto), A (Aperture priority), S (Shutter priority), and M (Manual). There are five scene programs modes available in which the camera will choose the optimal settings for the picture:
- Landscape + Portrait: Suitable for taking photos of both you subject and background. The picture is taken with the background as well as the subject in the foreground in focus.
- Landscape: Suitable for taking photos of landscapes and other outdoor scenes. Both the foreground and the background are in focus. Since blues and greens are reproduced vividly in this mode, the landscape mode is excellent for shooting natural scenery.
- Portrait: Suitable for shooting a portrait-style image of a person. This mode features an in-focus subject against a blurred background.
- Sports: Suitable for capturing fast-moving action such as sports scene or moving vehicles without blurring.
- Night scene: Suitable for taking night scene photos with a slower shutter speed.
