Question about The Watches
How do I change the time on my fit bit it is a hour ahead
    Top Expert:
  • The Master
  • 8,517 Answers
SOURCE:
I need to change time on my g910 watch that I purchased from a cruise the millennium I need to put 2 hours ahead to the Australian Melbourne time Thanks
no problem
when you get to your destination just set it to local time
Australia has the same 24 hours in a day time measurement as anywhere else
Oct 21, 2016 | The Watches
After setting to uk time, will revert to European time zone (1 hour ahead of uk)
It sounds like it it changing to BST...
Make sure the date is correct, and set to UST
British Summer Time
Universal Standard Time (GMT)
Apr 17, 2016 | Watches
I think i have an old one,but i have a two button illuminator watch. recently daylight savings began and im an hour ahead how do i change the time?
just reset the time as if the watch stopped
daylight time is not a special time just an hour earlier or later
Nov 08, 2015 | Casio Illuminator Watches
My g-shock ga-110c-1a hour hand is 6 hours ahead. The digital time is correct but the hour hand is six hours ahead. If i set the time at 6:00pm the hour hand will move to 12:00. the minute hand is fine, i...
go to support page on casio. and get your manual. youll probably gonna look for a 3 or 4 digit number located at the back of your watch. once you got the manual. go to page 4. and follow the steps of "Hand Home Position Correction". that should fix it.
i also have ga 110c and i have encountered this issue
Dec 29, 2010 | Casio G-Shock GW300CA-1V Wrist Watch
How do i change the hour? Only goes 6:40 and 5:40. cannot go back to 4:30 or ahead 24 hours.
I think you are changing from DST (daylight saving time) to local mean time.
Presumeably your problem is that the watch is not telling you the local time.
As the watch is radio controlled you can only change the time by choosing the location setting, so that the watch knows where you are.
Press the "mode" button to select the location abreviation and use other buttons to change to your local city.
When you have set the location, press the mode button to return to normal operation.
Jul 16, 2010 | Dakota Watch Company Radio Controlled...
The date changes at 12 in the evening
The watch is set-up for a 24 hour cycle. It sounds like your watch is 12 hours late, so if you just advance the time 12 hours ahead, everything should be solved.
May 23, 2009 | Tag Heuer WAF2110.BA0806 Aquaracer...
Armitron Watches
From the time telling mode press the set button the seconds will flash.
Press the mode button the hours will flash
Press the adjust button to change the hours
Press the mode button the minutes will flash
Press the adjust button to change the minutes
Press the mode button the month will flash
Press the adjust button to change the month
Press the mode button the date flashes
Press the adjust button to change the date
Press the mode button the day flashes
Press the adjust button to change the day
Press the set button when done.
Mar 11, 2008 | Watches
Setting time/date on Ironman Triathlon 8 lap
Press & hold set button the seconds will flash.
Press split/reset to set seconds to zero
Press mode to select hours
Press split reset to advance hour digits go through 12 hours to get to AM/PM
Press mode to select minutes
Press split reset to advance minutes
Keep repeatin the above steps to set month date day and 12/24 hour diplay
Press set when done.
Mar 09, 2008 | Timex Sports Ironman Triathlon 50-Lap...
Watches Logo
Top The Watches Experts
vince
D. E. Hev
 Larry
Larry
Are you a The Watch Expert? Answer questions, earn points and help others
