SOURCE: pronto M51 ...the yellow light is blinks and dosen't stop
Take your drive units both out of gear and put them back in that will reset the computer and it started mine working again.
SOURCE: manual for Pronto M51 wheelchair
Hi. We can supply, but try your local Invacare dealer. If you have luck, send us an email,
[email protected]
SOURCE: i have invacare pronto m51 with surestep the spjis
The 9 flash error code indicates a communications fault. The communication fault relates to the communication between the joystick and the control module. The joystick on the arm mount is connected to the control module in the base. When there is a break in the wiring of this wiring harness, also called a bus cable, a fault occurs. This trips the computer and the computer sends out a flash code to the joystick. Simply stated there is a broken or pinched wire between the joystick and controller. Look physically at the wire and check for cuts, breaks or pinches. The best short term repair is to repair the broken wire with solder and heat shrink or tape. You can also use **** splice connectors and tape. The best long term repair is to replace the harness with a part available from Invacare. The most definitive way to diagnose this problem is to read the fault log of the controller using a hand held programmer available to dealers and certified technicians. The number and type of fault codes logged in the controller is another indicator of which
component(s) has failed. Hope this helps.
SOURCE: my pronto m51 sure step service light is flashing
sarah check the joystick cable try unplugging it from the rear of the joystick and plugging it back in then unplug it at the back of the chair and plug it back then turn the chair on to see if you are still getting 7 flashes. If you are then you have one of 2 problems the joystick cable somehow is bad or the joystick itself has got a problem try the cables first to see if it fixes the problem If Medicare paid for the chair then they will pay for most of the repair Contact Roadrunner Mobility @ 1-800-467-2668 Hope this helps you
SOURCE: Hi, I have a pronto m51. The yellow led in the
If it's the yellow battery light it will blink when the battery voltage is very low, too low to drive and lower than the red blink.
The AMBER service indicator will light when an error or fault occurs. This is a yellow wrench shape. Refer to Diagnostic Codes on page 33 for a listing of the flash codes and what they indicate:
https://www.phc-online.com/v/vspfiles/V4_Backup/docs/MK5-NX_Electronics_Manual.pdf
