SOURCE: Motor spits and sputters
If it is old enough to have points then I would check them and make shure they are clean and gapped at .020. if that is noth the problem then it sounds like a fuel issue. Either a weak pump or a dirty carb.
SOURCE: 1964 5 1/2 hp evinrude kills at high speed
You should have a High Speed carb adjust and a Low Speed carb adjust. If it's running fine while idling, adjust the high speed setting. If you have two nobs, its the lower one. May be set wrong. If you don't have two nobs, remove the carburator and check the jets to make sure they are completely clean or better yet, order yourself a carb rebuild kit to take care of all of this. I just rebuilt my 1971 evinrude 4hp and the carb kit made the world of difference.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/matthew_d24b835e574ef6ca
SOURCE: why wont the throttle speed increase on my 20hp motor
Check the linkage under the hood and see if it is actually moving. They had a cheap plastic ball and socket. Then if all is well check that they are moving the throttle plate all the way open and finally see if you have spark on both cylinders and last but least is the engine have compression. If all those things are good, you may have lost a crankcase seal. While running, pull one plug wire off and re place it, then do the next on. If the engine quits= the bad cylinder will the the other one than the one in your hand.
