Radio Communications Logo
Martin Denomme Posted on Dec 12, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Does anyone know what the range is for the Motorola talkabout T5725? I can't seem to find it anywhere
eradiostore
Level 3:
  • Motorola Master 1,672 Answers
  • Posted on Aug 15, 2017
eradiostore
Motorola Master
Level 3:
Answers
1672
Questions
0
Helped
796975
Points
4248
As a general rule handheld radios will talk up to 2 miles line-of-sight. Anything you place between the two radios will reduce range. Talking from inside a building to outside, you can expect 1/4 to 1/2 mile. This being said, a radio can talk as far as it can see, so if you were on a mountain top, you could conceivably talk many miles into a valley below. Height and placement of your antenna determines range. Holding your antenna upright perpendicular to the earth will give you the best range.
5 Related Answers
Anonymous
  • 250 Answers
  • Posted on Jul 17, 2008
SOURCE: the talkabout t5500 and the t5725
Hello bella-9,
The T5500 is a 2 channel radio and the T5725 is a 14 channel radio. However, the radios should be compatible with each other on FRS channels 1-14 as long as both radios are using the same Quiet Talk code. If the Quiet Talk settings are different the radios will not be able to communicate with one another.
Assuming all settings are the same (as you say) and the units are within range of each other (typically less then a mile over clear, level terrain) they should work just fine.
Best Regards,
Ken
"Go Ahead. Use Us."
eradiostore
eradiostore
  • 1672 Answers
  • Posted on Nov 20, 2008
SOURCE: MOTOROLA TALKABOUT TWO WAY RADIOS WONT TRANSMITT- BOTH CAOME ON
Here is the manual for the T5720. It may be very similar to the model you have.
http://lib.store.yahoo.net/lib/starbattery/T56XXusersguide.pdf
eradiostore
eradiostore
  • 1672 Answers
  • Posted on Dec 19, 2008
SOURCE: MANUAL FOR talkabout model T5725 NEEDED
http://www.usersmanualguide.com/motorola/2-way_radio/t5700
eradiostore
eradiostore
  • 1672 Answers
  • Posted on May 30, 2009
SOURCE: i have a motorola T5725 talkabout and i want to disable the roger
Press and hold the + while you turn your radio on. Here is a link to the manual http://www.giantintl.com/RadioPDFs/Outdated%20Manuals/T56XX_57XX_User_Manual_E.pdf
eradiostore
eradiostore
  • 1672 Answers
  • Posted on Oct 24, 2012
SOURCE: Headset for Motorola Talkabout T5725
Try www.wirelesspro.com, we have found them to carry most of the TalkAbout accessories.
Best regards.
2answers
Does anyone know the range of the motorola t5725 walkie talkies
from what i can find out its saying up to two miles range
2answers
T5725 motorola manual needed
Here's a link to the user guide page, choose your model from the pulldown: http://shop.giantintl.com/Manuals.asp
T5725 manual
Download it from here: http://www.motorola.com/mdirect/manuals/T56XX_57XX_User%20_Manual_E.pdf
Motorola T5725 - Earpiece with mic wont work
A few things you might check:
1) Be certain the radio is turned off when plugging in any audio device.
2) Be certain the device is plugged in all the way. You should feel it seat, or click into place.
3) Use a device designed for your model radio. Aftermarket accessories don't always have the functionality of the OEM device.
4) Be certain you have special features such as VOX turned off on your radio.
Hope one of these helps.
Best regards.
Best regards.
The talkabout t5500 and the t5725
Hello bella-9,
Best Regards,
Ken
"Go Ahead. Use Us."
Top Motorola Radio Communications Experts
eradiostore
eradiostore
ZJ Limited
ZJ Limited
ExpressFiX
ExpressFiX
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
