SOURCE: samsung 340 cell phone
THIS WOULD PROBABLY BE AN INTERNAL PROBLEM YOU PROBABLY CANNOT FIX.SOME TYPE OF INTERNAL CONNECTION OR GROUND.YOU PROBABLY WILL NOT BE ABLE TO DO ANYTHING UNLESS IT IS UNDER WARRANTY
GOOD DAY
KZ
SOURCE: SAMSUNG LCD TV horizontal lines
causing of horizontal lines is leaky or defective capacitors. check big value capacitors around the board at Horizontal area. check the filter capacitor as well. good luck
SOURCE: Samsung HLS 5679W LED DLP TV Horizontal white lines jagged across screen.
What you are sseing is a convergence problem within the light engine of the set. This is not repairable in teh field other than replacing the light engine part. Since this unit is less than one year old, it should be covered under warranty. From the looks of it, one of the LCD panels has shifted internally. Call for warranty service and indicate that the light engine has a problem. With luck, the service company will show up with the part in hand. Replacement should not take more than an hour or so.
Dan
SOURCE: Samsung Plasma Lines and Colors on Screen
yes it can fix. its only loose connections from LCD connectors. trust me. [email protected]
