Re: Phillips 60pp9202-17 TV has sound, but no picture, no...
Hold flashlight up to screen to see if back light is out. If it's out you'll see video.if it's an older flat screen it could have a bad inverter board.
If its chirping contantly when powered on take a look at the chirping tv repair kit on the site www.TvRepairKits.com If its not chirping the next most common failure is the flyback
I need to know first if your TV is on standby mode (red LED lit) or not?..If the green light lit your TV your high voltage (HV) is switch but you have open line on heater that cause of no picture and the sounds is chirping because of analog(antenna)/digital connection or bad audio chips..
I need this information above for specific diagnosis and to prevent more damage and failure..Also I need this information to avoid mistakes to buy a parts with no help...
also I need the model # because on my tread there are 2 model # which are correct? is it 60PP9202 60" or 55PP8620?..for specific diagnosis and for possible get a diagram..
chirping sound is a short of some kind, could be the flyack or horizontal output, could also be a bad picture tube or power supply capacitors, you really need a tv repairman to troubleshoot this.
I had the same exact problem pulled the chassis ohmed the convergance ics though one read different than the other replaced both put chassis back in set fired right up.Hope this solves your problem!
