SOURCE: Quick repetitive disconnects
try to upgrade the latest firmware for the router and that would fix this problem, if u have any other wireless device operating in the same frequency of your router, try to swich off your other devices and check, if still the same, replace the product..
SOURCE: my pc wont accept my mymusix player
I solved this problem by:
1) First, uninstalling the device using the Device Manager. (I.e., control panel --> System icon --> Hardware tab --> Device Manager button. The device is located under Portable Devices. For me it had a name like MTP Device -- I don't recall the exact name. Right click on the device and select Uninstall from the pop-up menu.)
2) Second, I disconnected the player physically from the PC.
3) Third, I followed the PD-6070 FAQ page instructions (found at http://www.mymusix.com/) entitled Q: How to recover my player's firmware?
The PD-6070 player is now detected properly and my daughter is very happy!
SOURCE: POWER ACOUSTIK PD-931NB won't turn off when my
It is miss wired to power instead of the switch that turns off the car.
its not supposed to do that,read your manual,it only reads memory cards,,it plays dvds
Power Acoustik PD 103B
This is indicative of a failed/failing lcd screen. If under warranty return to manufacturer. If not probably cheaper to replace.
