When I replace empty cartridges with new it still shows "low" on yellow and Magenta when printing. Others show half full when new and full. I use new Canon cartridges. Tried a different supplier and still the same.
Are you sure its exclamation mark?.. This warning message related to print head. (warn out). When you are replacing ink tube assembly use dummy print heads to do the priming (new ink tubes are empty & they have to fill with ink).. Action: Remove all cartridges and print heads, switch on the printer follow the screen message.(Insert cartridges first next dummy print heads).once its recognizes cartridges then it switch over to print heads,insert dummy print heads. Once printer recognized the dummy print heads, printer will perform priming, during priming dummy print heads will filled with respective inks.(follow the display message)Remove dummy print heads & insert normal print heads. Wait till printer recognizes print heads, load the paper & wait till performs the calibration, once calibration is successfully done issue closed. If calibration not successfully done, check align print out for which print head is not printed properly, replace it.. Pl ensure that minimum 50% ink levels required in cartridges before performing the priming. Best of luck..
maybe the cartridge is wrong, release it and clean the electrical contacts, put them again one by one, if notting happen, try this
Solution
As the printer operates, it moves ink from the ink cartridges into a printhead reservoir. The printer does not deliver a message when an ink cartridge goes empty, because it still has ink in the reservoir. The printer continues printing until the ink level in the reservoir falls to a first trigger point - then a message appears advising the printer owner to Replace Cartridges Soon . At this point, other cartridges that are empty but have not reached the trigger point are also mentioned in the message, to save trips to the retailer. After the first trigger point, the printer can continue printing until ink levels in the reservoir reach a second trigger point. At the second trigger point there is only enough ink left to perform vital servicing tasks, and a new message appears, saying Ink Cartridges Empty . The options offered depend on the usable inks remaining. If no options are offered, the cartridges indicated must be replaced before printing can continue.
The Ink Cartridges Empty options are described in the table below:
Ink colors outOptionPrint mode possible
All
Cancel
None
Black
AND
Cyan, Magenta, or Yellow (any or all)
Black only
Continue with other colors
Cyan/Magenta/Yellow mode (composite black)
Text and photo quality will differ from those printed when all colors are available
Light Cyan or Light Magenta (either or both)
(Black still available)
Print with black ink only
Grayscale
Are you using a factory new ink cartridge?
If you are using a refilled or third party cartridge that may well be your problem.Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using factory new cartridges, then please call the manufacturers Technical Support for assistance with the warranty on the cartridges
Don
Hi there. The reason for your problem is that the colour cartridge contains cyan, magenta and yellow ink, plus a black cartridge of course. All the other myriad colours are produced by mixing these four basic colours. So, if you print red, it requires ink from both the magenta and yellow cartridges. Thus if your red produces a yellow print, it means your magenta is not printing. This can be due to a number of reasons, mainly an empty or faulty magenta cartridge or blocked magenta print nozzles.
If you wish me to help you with sorting out the lack of magenta, please post a new comment to this effect.
IT IS POSSABLE THAT THE PRINT HEAD ARE DIRTY THEY HAHVE MATCHING BOARDS TO THE TONER CARTRIDGE BOARDS UNPLUG THE MACHINE AND CLEAN THE PRINT HEAD WITH ALCOHOL IF IT DOESN'T WORK THE BOARDS HAVE FAILED
