Washing Machines Logo
Marty Head Posted on Dec 10, 2016
Hi I have a Bosch Vario Perfect 1200 machine and it;s been perfect for a year or two. Now it has started randomly not spinning. We have to manually select the spin cycle and it spins. Please help.
malcolm lawrie
Level 1:
New Friend:
  • Contributor 14 Answers
  • Posted on Dec 10, 2016
malcolm lawrie
Contributor
Level 1:
New Friend:
Answers
14
Questions
0
Helped
1735
Points
19
Check pump filter to see if it is blocked normally a hatch at front of machine
5 Related Answers
barkencoa
Barry Coates
  • 3463 Answers
  • Posted on Dec 22, 2008
SOURCE: Bosch Classixx 1200 Express wont spin!!!! HELP
Make sure that all the water has drained from the washer, if it has a filter, remove and clean, it is located behind a removable plastic panel at the front of the m/c, if it still does not spin, suggest you remove motor and check the brushes for wear, this is often the reason it won't spin, but will wash o/k.
Plz rate my solution.
Thanks
Anonymous
  • 130 Answers
  • Posted on Feb 16, 2009
SOURCE: BOSCH WASHING MACHINE WONT SPIN, FLASHING RED SPIN LIGHT
check the pump clean out. sounds like something is jammed in the pump
Anonymous
  • Posted on Jul 23, 2009
SOURCE: bosch 1200 classic express washing machine wont spin
Providing the machine isn't requiring major breakdown repair, the problem should be solved by emptying the machine and cleaning the drain pump. If this is obstructed the maching won't drain or spin as any bits left in clothes (paper clips, coins, nails, screws etc) wedge themselves into the (what I call a fly wheel) the pump impeller wheel at the back. If the fly wheel can't rotate the machine cannot pump or spin.
So.........turn off the washing machine before you fiddle about with it. Then, at the bottom right-hand side at the front of the machine there's a drop down door. Take this down and take it off. Then, lower the drain hose from its holder and pull the hose out of its housing. Be very careful if you're doing this while you have very hot water in the machine. To be safe, let the water cool before starting. Next take off the closing cap from the hose and empty the water from the machine. There are times when the water doesn't empty by this method so carefully open the door to the machine and bale it out. If the water does come out via the hose, have a suitably sized bucket at the ready as up to 20litres can be drained. Once you've done this, put back the closing cap of the drain hose and returned the drain hose to its holder, unscrew (anti clockwise) the petrol tank cap look-a-like placing a towel underneath as a little residual water will flow out. The pump impeller (fly wheel) must be able to rotate so clean out any residual fluff from the thread of the pump cap and pump housing before returning the pump cover and screwing tightly on. Put back the drop down flap and, hopefully, away you'll go again.
Hope this is of some help.
Anonymous
  • Posted on Sep 13, 2009
SOURCE: bosch exxcel wf02465 wont spin
We had similar problem, with the spin cycle not working. We opened the 'drain' pipe (front-right bottom side). It was full of lime scale; never been opened for years. We cleaned it up and the spin cycle is now working.
barkencoa
Barry Coates
  • 3463 Answers
  • Posted on Dec 09, 2009
SOURCE: my Bosch classic 1200 express washing machine wont drain or spin
Possibly a blocked filter or pump.
Ths filter should be at the bottom right front of washer, sometimes behind a removeable cover at the bottom of washer.
To clean it, unscrew anti-clockwise, remove and clean.
Our Bosch maxx vario perfect doesn't want to let water in
Check if the inlet pipe has not twisted,if ok unplug machine remove top and (if confident enough) get a multi meter to check if the coil is not open circuit (broken),if so replace it eric992
1helpful
Cl what does this mean as cant put machine on
If the washer won't start the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Normally "Cl" stands for child lock.
How do i take child lock off my bosch washing machine
Press and hold the start button, can take up to 10 seconds
Errore f00 lavatrice bosch
Errore F:00 lavatrice bosch ecomaxx7 vario perfect
I have a Bosch Logixx 8 Vario perfect washing machine. Its only a few months old. My problem is that the conditioner is still in the drawer after the wash is finished. What do I do
Bosch Logixx 8 Vario problem is that the conditioner is still in the drawer after the wash is finished This video will show you how to keep your soap draw clear and how to service the parts
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Top Bosch Washing Machines Experts
NOEL
NOEL
Oliver Street
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
