SOURCE: Thermador wcggcv30 gas cooktop - how to remove glass top
Remove the brass ring nuts and the screw from each of the burners and pull off the knobs, then lift up the glass cooktop; no need to remove the three screws around the perimeter or even take out the box.
SOURCE: broken glass cook top
You probably need to replace it. They are though fairly expensive. A little under $200 to be exact. http://www.partstore.com/ModelSearch.aspx?MfgName=Maytag&BrandName=JennAir&CloselyRelatedModels=true&ModelNumber=JED8430&x=41&y=30
The top can not be repaired. The glass must be replaced . DO NOT USE IT CRACKED!!!!!!!!!!!! This is very dangerous as it can explode from the temperature. Also this is a severe electrical danger as glass top units have exposed elements underneath. Any liquid at all can short it out and cause a fire. I don't know if it is worth repairing. I don't have the exact price for your cooktop but last one I priced was between $350 - $500.
SOURCE: glass top
The cooktop will need to be removed from the counter. Turn it upside down and remove the screws. The biggest problem will be removing the cooktop from the counter. Sometimes it is not worth fixing as the part could cost around $400. NEVER use a cracked top as it could suddenly explode. This is tempered glass and very unstable if cracked or chipped.
SOURCE: ge jp340 radiant cooktop
Hello
I have the manual for your stove in PDF format, I will gladly email it to you.
Eddie Rentas
Tupper Lake NY
