Health & Beauty Logo
r
ralph schwartz Posted on Dec 08, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
.I have an old quickie p 190 power wheelchair. no manual. batteries will not charge, I need new batteries but ido not know which ones. would also like a user manual. Which batteries do I need?
wcdoc1953
Level 2:
  • Expert 280 Answers
  • Posted on Dec 21, 2016
wcdoc1953
Expert
Level 2:
Answers
280
Questions
0
Helped
129789
Points
552
The batteries that fit this chair are 35 amp hour or U-1 batteries.
There was an upgrade to the battery boxes which included changing the circuit breakers from 30 to 50 amp and removing the internal battery tray to accommodate group 22 batteries. This was not the most popular configuration. Buy U-1 batteries which are guaranteed to work. Hope this helps.
Batteries are charging fine but once you run the chair it drains the batteries
Hi
this is usually what occurs when the batteries are failing, much like a car battery as they age they charge fine but the amount of stored power is gradually reduced till eventually it will no longer start the car
The only time the chair worked [approx. 1/2 hour] was when the repairman cleaned the cables. Since that, the chair charges, turns green for full charge, and only flashes red as soon as the joystick is...
hi.
the link below is for the owners manual for the quickie aspire power wheelchair, free download in pdf format.
http://www.wheelchair-review.co.uk/wheelchair-files/wheelchair-manuals/sunrise-medical-wheelchairs/quickie-aspire-power-wheelchair.pdf
the "cane crutch holder" is an acessory part that you can get, fitted to the back of the seat, to hold a crutch or cane. it does not affect the chair itself at all.
there are two most likely reasons for your problem, neither of which actually involve the arm and controller.
1. if the battery light is flashing 9 times when you try to move, then you need to check the motor locks are engaged properly. see page 27 of the manual for photos and location. these are also known as "freewheel levers" and allow you to disconnect the motors to push the chair manually. if the levers are engaged properly, it is quite possible that the switch, or switch wires have broken and the chair thinks that they are off. these are very cheap and easy to replace and are located where the lever connects inside the chair.
2. if the battery light comes on and stays on, then you may need to have the batteries checked. if the batteries have not been charged for a while then sulphur may have built up on the lead plates inside the battery. this can mean that the batteries will show fully charged, but as soon as you try to draw power, they cannot function due to the sulphur, and instantly show as flat.
any auto shop should be able to perform a battery load test for you to test this. a 100amp load test for about 6 seconds will test the battery performance and let you know if they need replacing. most places will do this test for free but the batteries need to be fully charged first.
hopefully, one of these solutions will work as these are the most common fault for the symptoms you are describing. you should find the manual quite useful as well.
please feel free to ask if you need more information.
hope this helps
2helpful
I have a quickie electric wheelchair. The right axle was locked up. I turned the power on and now all I get is a flashing light. The batteries are new and fully charged. What could the issue be? The home...
The right motor will need to be replaced. What reason did they give why Meduicare wouldn't pay for repair If the Aspire is your only chair then Medicare will pay. If you have received a new chair since the Aspire then Medicare will only pay for repair to the newer chair. You can contact a repair service other than the home Medical to get the chair fixed. You can contact Roadrunner Mobility @ 1-800-467-2668 for repair Hope this helps you
1helpful
Have a Sunrise Aspire chair w/new batterie, charged by the repairman. Want to keep it charged regularly (not let it run down). DO I NEED TO TOTALLY DISCONNECT THE POWER HOOKUPS IN THE BACK when I...
You do not need to unplug the large 9 pin beau plug in the rear or the smaller 3 pin molex plug when you charge the chair. Do not unplug them or you will not charge the chair.
Use your charging cord as you describe "plug it into the front, plug it into the wall and charge, then unplug the charger cord and GO". Hope this helps.
2answers
After two or three minutes of travel, the power
You got some bad batteries or your charger is not working. If Medicare purchased the chair contact Repair Xpress at 1-877-581-3733 Medicare will pay for most of the repairs
Flashing battery life lights, quickie 525s
The chair is either in freewheel or the number of flashes will indicate an error code to tell what the problem is. Look in your users manual for error codes or contact Sunrise Medical Tech support
When you turn the chair on the light just binks
If it is just one red light blinking, then your batteries are below the level necessary to power the chair. Charge and see if they come back up, or replace if they won't.
Aspire Quickie Battery Charger
most chargers have an external or internal fuse, try replacing.
2answers
Battery charger not charging
Try calling Sunrise @(303) 218-4500
   Will the battery charger even come on?
Top Health & Beauty Experts
Rob Hill
Rob Hill
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Health and Beauty Expert? Answer questions, earn points and help others
