If you are experiencing a mid-range humming from your monitors when using your Allen & Heath PA12-CP mixer, there may be a problem with the signal level or the cables.
Here are a few steps you can try to troubleshoot and resolve this issue:
- Check the signal level of the sources that are being sent to the monitors (e.g. kick drum, snare, etc.). Make sure they are not too loud or too quiet, as this can cause the limiter to engage and create a humming sound.
- Check the cables that are connected to the monitors. Make sure they are not damaged or loose, and that they are properly connected to the mixer and the monitors.
- Try using a different set of monitors to see if the problem persists. If the humming is still present, the problem may be with the mixer itself.
- If you are still experiencing a humming sound, you may need to contact Allen & Heath customer support for assistance. They will be able to provide you with more detailed troubleshooting steps and help you resolve the issue.
Overall, if you are experiencing a humming sound from your monitors when using your Allen & Heath PA12-CP mixer, the problem may be with the signal level, the cables, or the mixer itself. Follow the steps above to troubleshoot and resolve the issue.
