Is there a way to program one of the auto dial buttons to intercom everyone in the office simultaneously?
SOURCE: Meridian Norstar M7310 -- Phone's buttons seem disabled.
Sounds like a stuck button!
Look for the button that is depressed... or the button that has that person that the set is always calling and remove that button with a key/ small knife/ screwdriver or something.
When you take this button off the set, I bet that your set will start working again.
Clean that button, maybe there is something spilled on it.
Good Luck.
SOURCE: Ringing multiple intercom numbers at once
That was a good solution to the problem. way to go.
SOURCE: lines ring to intercom
It sounds like although they're labeled as line buttons actually they're programmed as station buttons.
If you press feature *0 and one of the buttons it will tell you what the button is programmed as.
Also did you try pressing the intercom button then dialing 9? that might be the way the set was programmed.
