Power cycle your TV: Turn off the TV using the remote control, unplug the power cord from the power outlet, wait for at least 5 minutes, plug the power cord back into the power source, and then turn on the TV .
Check your internet connection: If your TV is freezing when downloading, it could be due to a poor internet connection. You can check your internet speed by visiting speedtest.net on your TV's browser. If you have a slow internet speed, try disconnecting other devices connected to the Wi-Fi router while watching shows on Prime Video .
Factory reset your TV: If the above steps don't work, you can try factory resetting your TV. To do this, turn on your Hisense TV and navigate to Menu by pressing the "MENU" button. Proceed by selecting "Support" with the "Select" or "OK" button. Start the self-diagnosis by pressing "OK". Choose the "Reset" option now.
Hi Cindy, unplug the TV for 10 minutes and try again
If you do not succeed, reset the TV to Factory Settings
I send you the link to download your Hisense manual
I hope you can solve the problem
Greetings Franco Dosil
Hola Cindy, desenchufa el televisor por 10 minutos e intenta nuevamente
Si no lo logras, resetea a Ajustes de Fabrica el televisor
Te envio el link para que descargues el manual de tu Hisense
Espero puedas solucionar el problema
Saludos Franco Dosil
You have to reset the set electronics to erase all prior settings. Look for reset button on unit or contact Hsense. Also, in the settings area for internet there may be an area for a totally new network.
Don't know that much about Hisense but other brands when you connect to your modem you will have to pair the tv and it up with your wep password. Tv should ask you all of this in set-up screen.
As long as your source & connecting cable are good, most likely issue is the MAIN PCB. unable to locate any parts without, model#, you might contact HISENSE with the model#
