SOURCE: sub+amp configuration
With a single 4-ohm subwoofer, usually the best choice is a 2-channel amp that can be bridged to a single channel. In your case, the sub is rated for 1000 watts. Not many amps are rated for that kind of continuous power into a 4-ohm load. Kicker doesn't list a minimum power rating, which isn't unusual in subwoofer specs. Depending on your budget, I'd look for an amp rated for 300-500 watts minimum; the higher, the better, up to 1000 watts. Most amps will have several power ratings, based on the load impedance and number of channels driven. A typical 2-channel amp might be rated like this: 150 watts x 2 channels at 4 ohms 300 watts x 2 channels at 2 ohms 500 watts x 1 channel at 4 ohms. The power rating you'll want to look at will be the 1-channel, 4-ohm rating. You can look at mono amps, too, but in the power ranges you're looking for, a 2-channel amp will probably give you the best value. However, if you can find a mono amp with a high enough 4-ohm power rating, it would run cooler and might last longer than a 2-channel amp with comparable power. When looking at mono amps, you'll find their highest power output will be at 2 ohms or 1 ohm; make sure you're checking the 4-ohm rating when making comparisons. Some amplifiers that might work well for you: Kicker SX900.2 Kicker ZX850.2 Alpine PDX-1.1000 Rockford T600-2 Hifonics ZXi 1006 Premier PRS-D2100T Power Acoustik OV2-2200
SOURCE: speaker wiring
hi mat
you should have four terminals two plain and two with dots
to get the best power cut two inches off good speker wire
tear apart now place one wire from
plan black to red with white dot then
plain red to black with white dot
this is how set then up with my directed 1100d mono amp .. very loud at half gain
well hope this helps.............. ..benjaminsarmy..
SOURCE: Powering 4 6x9 speakers, need amp
Hi firstof all your deck isnt really putting out 52 watts x4 more like 17-22w rmsx4 ,companies like to throw out some crazy numbers it seems. If your into Kenwood try out a KAC-8404 4-channel on the mids/highs that will put 50 w x4 rms at 4 ohms or if you wanna go a lil louder try the kenwood x600f that will throw 100w rms on each 6x9 at 4 ohms no problem. My system is very similar to yours but running 4 pioneer 5x7's in all the doors and powering it with the 8404 its loud and clean ,fan cooled and no problems at all. My subs are a pair of 15's soundstream t-4's powered by an Alphasonik pma2500a its throwing 800w rms on each sub running in stereo at 2 ohms.It can drown out the mids if i set it that way but my mids /highs cant take as much power as your kenwoods can or else id step up to the x600f too.
SOURCE: wireing two dual 4 ohm kicker cvr 15s on a memphis
CVR series do not have large power handling capabilities.
Your subs will melt before the amplifier is used to its full potential.
If the subs arent in a ported enclosure - do that.
They both handle 500w rms - so the pr1000 is perfect.
bass response is all in the enclosure!
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
SOURCE: can i hook up my sub if it's wired to a 2 ohm and my amp is 4 ohm
Hi martineztag
You should never connect a load of an impedance less than the min the amp is able to drive. This can have disastrous consequences that may easily result in failure of the amps output stages. You need to use a different configuration that does not overload the amp in this manner for safe operation.
regards
robotek
Testimonial: "Thanks for the help should i just leave it 4ohms how do i wire it like that? "
