Question about Konica Minolta Bizhub C554 Color Copier / Printer / Scanner
Bizhub c554e error code c4801 - Konica Minolta Bizhub C554 Color Copier / Printer / Scanner
  • Konica Minolta Master
  • 6,850 Answers
MFP detects simultaneous replacement of multiple boards. YOU REPLACED board and did not follow the service manual
Do not replace the printer control board and the SSD board at the same time. The backup data is lost and image failure may be
caused.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Posted on Mar 12, 2017
SOURCE:
Hi all. I've been having a problem with my bizhub c554e that i've been working on. which is when i change the drum core (K) and also the drum blade, the printing for (K) became not satisfiable. which is...
Black drum for the 554e is the same as the c364. Replace the drum as OEM not third party and DONT do it your self replace the whole drum from a Konicaminolta and the developer unit also
May 10, 2018 | Konica Minolta bizhub Office Equipment &...
Bizhub 554e error code C-4801
C4801
(1) Contents Trouble type Main unit board failure
Trouble code C4801 Rank C
Detection timing MFP detects simultaneous replacement of multiple boards.
Trouble isolation -
Relevant electrical parts • SSD board (SSDB)
• Printer control board (PRCB)
(2) Procedure
Step Action Control signal Location of electrical components
1 Reinstall the old PRCB. - -
2 If the above actions do not solve the problem, contact
KM. - -
NOTE
• Do not replace the printer control board and the SSD board at the same time. The backup data is lost and image failure may be
caused.
Dec 29, 2016 | Konica Minolta bizhub Office Equipment &...
Error code C4801
no such code for C220
Sep 16, 2015 | Konica Minolta Bizhub C220 Color...
Error code c4801 For C284e
You may have main board issues. Maybe Try error code reset.
Open front door and locate main power switch on the bottom left and turn off.
Press and hold the reset button , button on control panel.
Turn main power switch back on whilst pressing reset.
after 1 - 2 min a white screen with 1 button saying"error code reset will appear , let goo of reset button.
Press error code reset and then turn main power switch of for 20 seconds. turn main power switch.
If code returns contact me on my phone to discuss
Sep 02, 2014 | Konica Minolta bizhub Office Equipment &...
How do I fix trouble code c- 0204 on my bizhub C554e Photocopier machine?
Tray 2 feeder up/down abnormality.The paper feed tray 2 upper limit sensor is not blocked even after the lapse of a given period of time after the lifting motion has been started.Check the sensor and the sensor actuatos.
Jul 14, 2014 | Konica Minolta bizhub 250 All-In-One Laser...
Why do i get a error code c1105 on my bizhub c554e and how do i fix it
Sorry your having trouble. Your code suggest you have an optional KM FS-534-535 finisher attached to your copier. The code is triggered by an internal part within the finisher and should be thoroughly inspected only by a certified factory trained service technician. I would suggest you contact your local repair company.
Attempting to resolve this issue on your own could produce negative results.
May 31, 2014 | Konica Minolta Bizhub 222 Black and White...
Konicaminolta bizhub c554e
good machine
Jan 17, 2014 | Konica Minolta bizhub Office Equipment &...
Konica Minolta Bizhub C554 Color Copier / Printer / Scanner Logo
215 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
