Washing Machines Logo
Annie Gilley Posted on Dec 05, 2016
NEPTUNE WASHER BEEPS,,WANT TURN OFF OR START
LIGHTS ARE ON ANY BUTTON P4RESSED CAUSES IT TO BEEP A FEW TIMES,,BUT WILL NOT START OR TURN OFF
Scott Thompson
Level 1:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 1 Answer
  • Posted on Dec 31, 2019
Scott Thompson
Contributor
Level 1:
Welcome Back:
Answers
Questions
0
Helped
1098
Points
When door locks like that next time. If you remove the top of the machine. Reach down inside on left side. There is a small wire cable that you pull up on. Will manually unlock the door. Then plug power cord in to wall. Power it on let it go through reset cycle and it will work properly again. However if you can't reach the latch through the top. Tilt washer forward and reach up from the bottom. If you get an F1 code it's low water pressure.
5 Related Answers
A
Anonymous
  • Posted on Mar 18, 2008
SOURCE: Pushing Start Button only results in "Beep, beep, beep"
Actually, what appears to have happened is that somehow the door locked while it was open. I've ordered the door latch mechanism and the repairman is coming as soon as the part arrives. Good thing too. The seal around the inside of the drum was torn in places and leaking water. We've ordered that too. Thanks for all your suggestions. By the way - there was no error code at all. Hopefully this will all help someone else.
Anonymous
  • Posted on Aug 29, 2008
SOURCE: maytag neptune
i have maytag neptune wash,modelo mah5500bww,my problem is: no starting,flashing start/pause button,after ten minutes is off.And now is ready for start when press start/pause button
Anonymous
  • 121 Answers
  • Posted on Nov 30, 2008
SOURCE: maytag neptune washer display showing FL
fl is a over fill. clean the pump out and the sump near the pump is in the back the dran hose goes to it
Anonymous
  • 11 Answers
  • Posted on Dec 28, 2008
SOURCE: Maytag neptune washer: will not start
plug a light into the washer outlet to check for elec current at this point before anything else.
unvme
Harold Case Jr.
  • 266 Answers
  • Posted on Jan 25, 2009
SOURCE: Won't Start - Beep-beep-beep
unplug it then plug it back in to see if it helps
2answers
My presario 1600 just beeps when I turn it on...
there are 4 kinds of beeps that the pc produce when you turn it on, base on your beep it is indicating that the memmory is damage,
a single beep means the pc is ok
and your beep is memmory damage
a long beep pause and then beep long again means video card damage
if the beep sound like a firetruck the processor or memmory is over heating
Washer wont start with all panel lights on
usually unplugging it will reset the ECU ( main control board ). is the door lock operating correctly? i have seen them do that if he door look isnt functioning correctly. the owners manual might be helpful if you can find it or maybe download it from maytag site.
Wahing machine
Try pushing the skip button this may reset the prog. These machines will beep to indicate a fault. Dependant on how many times the machine beeps b4 it pauses ie 1 beep then a pause would indicate the machine isn't filling, 2 beeps its not pumping out, 4 beeps doors open. Hope this helps
Machine beeps but won't start
does it say do in the display as if the door is open??
All buttons cause machine to beep
Trying unplugging for 20 minutes maybe you can reset it.
2answers
Maytag washer
Maybe you over-loaded, or you did not shut the door properly. Try reading the users' manual.
Maytag washer
It helps trying to actually weigh your dirty linen. Try to wash within what is mentioned in your manual. Also see that the door is closed firmly. Would be useful if you'd post back results.....
Top Maytag Washing Machines Experts
ZJ Limited
ZJ Limited
john h
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
