Cars & Trucks Logo
J
James P Smith Posted on Dec 05, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The wiring route for rear speakers. Front to back on 1990 Oldsmobile tornado/trofeao
Marvin
Level 3:
Top Expert:
  • Oldsmobile Master 85,242 Answers
  • Posted on Dec 05, 2016
Marvin
Oldsmobile Master
Level 3:
Top Expert:
Answers
85242
Questions
28
Helped
29052872
Points
266281
The wires run under the door opening sill plates, usually on the drivers side but check both sides.
The wire colors should be as below.
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
PINOUT FOR FORD FOTF-19B132-AA RADIO
1990 Ford F150 Truck Car Radio Wiring Schematic
Car Radio Battery Constant 12v+ Wire: Green/Yellow
Car Radio Accessory Switched 12v+ Wire: Yellow/Black
Car Radio Ground Wire: Red or Black
Car Radio Illumination Wire: Blue/Red
Left Front Speaker Positive Wire (+): Orange/Green
Left Front Speaker Negative Wire (-): Black/White
Right Front Speaker Positive Wire (+): White/Green
Right Front Speaker Negative Wire (-): Black/White
Left Rear Speaker Positive Wire (+): Pink/Green
Left Rear Speaker Negative Wire (-): Pink/Blue
Right Rear Speaker Positive Wire (+): Pink/Blue
Right Rear Speaker Negative Wire (-): Green/Orange
Wiring diagram/stereo
THis could helpful... 1998 Oldsmobile Intrigue Car Stereo Radio Wiring DiagramRadio Constant 12V+ Wire: OrangeRadio Ignition Switched 12V+ Wire: YellowRadio Ground Wire: Black/WhiteRadio Illumination Dimmer Wire: Gray/BlackRadio Antenna Trigger Wire: Dark GreenRadio Amplifier Trigger Wire: N/AFront Speakers Size: 5 1/4" SpeakersFront Speakers Location: DoorsLeft Front Speaker Wire (+): TanLeft Front Speaker Wire (-): GrayRight Front Speaker Wire (+): Light GreenRight Front Speaker Wire (-): Dark GreenRear Speakers Size: 6" x 9" SpeakersRear Speakers Location: Rear DeckLeft Rear Speaker Wire (+): BrownLeft Rear Speaker Wire (-): YellowRight Rear Speaker Wire (+): Dark BlueRight Rear Speaker Wire (-): Light Blue
Hope helps.
I have a 1990 Celica, trying to put in new radio. Got everything wired up correctly, Constant - blue/yellow, acc - gray, ground - brown and it won't come on. Radio fuse (top center 15 amp) is good,...
You have it right. Use a 12 volt test light to see if there is power between the gray and brown wires when the key is on. If there is power there, you may have got hold of a bad radio.
1990 Toyota Celica Car Stereo Radio Wiring Diagram
Radio Constant 12V+ Wire: Blue/Yellow, connects to yellow
Radio Switched 12V+ Wire: Gray, connects to red
Radio Ground Wire: Brown, connects to black
Radio Illumination Wire: Green, do not use
Radio Dimmer Wire: N/A
Radio Power Antenna Trigger Wire: Black/Red
Radio Amplifier Turn On Trigger Wire: N/A
Front Speakers Size: 4? Speakersir?t=modilife-20&l=as2&o=1&a=b00009uhre
Front Speakers Location: Dash
Left Front Speaker Wire (+): Pink
Left Front Speaker Wire (-): Purple
Right Front Speaker Wire (-): Blue
Rear Speakers Size: 5 1/4? Speakersir?t=modilife-20&l=as2&o=1&a=b00009uhre
Rear Speakers Location: Side Panels
Left Rear Speaker Wire (+): Black
Right Rear Speaker Wire (+): Red
Right Rear Speaker Wire (-): White
I have a 1990 crown vic and the speakers are bad and i need to know what the speaker wire color coding is for the front ad back speakers.
Got this from http://www.modifiedlife.com/1990-ford-crown-victoria-car-stereo-wiring-schematic/ I have used this site before, and the wiring guide was accurate for my grand marquis
Car Radio Ground Wire: Chassis
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 5 1/4? Speakersir?t=modilife-20&l=as2&o=1&a=b00009uhre
Car Audio Front Speakers Location: Doors
Car Audio Rear Speakers Size: 6? x 9? Speakersir?t=modilife-20&l=as2&o=1&a=b00009uhre
Car Audio Rear Speakers Location: Rear Deck
2helpful
2answers
I HAVE A 1990 TOYOTA CAMRY AND I NEED A WIRING DIAGRAM FOR RADIO INSTALLATION.
does this help, or do you need more?
1990 Toyota Camry Car Stereo Radio Wiring Diagram
Front Speakers Size: 3 1/2?
1helpful
I need the audio wiring diagram for 1990 mazda B series
1990 Mazda B2000 B-Series Pickup Car Stereo Radio Wiring Diagram.
Car Radio Constant 12V+ Wire: Blue/Red
Car Radio Switched 12V+ Wire: Red/Black
Car Radio Illumination Wire: Blue/White
Car Radio Dimmer Wire: N/A
Car Radio Antenna Trigger N/A
Car Radio Amp Trigger Wire: N/A
Front Speakers Size: 4′
Left Front Speaker Wire (+): Blue/Red
Left Front Speaker Wire (-): Blue/Yellow
Right Front Speaker Wire (+): Blue
Right Front Speaker Wire (-): Blue/White
Rear Speakers Size: 4′
Rear Speakers Location: Rear Corners
Left Rear Speaker Wire (+): Blue/Red
Left Rear Speaker Wire (-): Blue/Green
Right Rear Speaker Wire (+): Blue/White
Right Rear Speaker Wire (-): Blue/Green
pls rate
4helpful
My wiring plug to the back of the radio was cut on my 1990 4runne
fun fun fun.
1990 Toyota 4Runner Car Stereo Wiring Schematic
Car Radio Battery Constant 12v+ Wire: Blue/Yellow or Blue/Black
Car Radio Accessory Switched 12v+ Wire: Gray
Car Radio Ground Wire: Brown
Car Radio Illumination Wire: Green
Car Audio Front Speakers Size: 4′
Car Audio Front Speakers Location: Dash
Left Front Speaker Positive Wire (+): Pink
Left Front Speaker Negative Wire (-): Purple
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Blue
Car Audio Rear Speakers Size: 5 1/4′
Car Audio Rear Speakers Location: Side Panels
Left Rear Speaker Positive Wire (+): Black
Right Rear Speaker Positive Wire (+): Red
Right Rear Speaker Negative Wire (-): White
Need stereo diagram for 1990 Ford thunderbird.
1990 Ford Thunderbird Car Stereo Wiring Diagram
Car Radio Ground Wire: Black/Light Green
Car Stereo Antenna Trigger Wire: Orange/Blue
Car Audio Front Speakers Size: 5′ x 7′
Car Audio Rear Speakers Size: 5′ x 7′
7helpful
I need raido wiring diagram for 1990 corolla
1990 Toyota Corolla Stereo Wiring Diagram
Radio Antenna Trigger Wire: N/A
Right Front Speaker Wire (+): Purple
Right Front Speaker Wire (-): Light Green
1helpful
Toyota corina
1990 Toyota Corolla Car Stereo Radio Wiring Diagram.
Top Oldsmobile Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you an Oldsmobile Expert? Answer questions, earn points and help others
