SOURCE: TV screen goes blank but power stays on
Sounds like the CRTs are going into protective blanking due to the vertical output ic needing to be resolderd. Try resoldering the vertical IC that may possibly fix the issue.
SOURCE: My Ant A Input Not Working
Good Day, babt;
TRY THIS:
MAY ONLY BE ABLE TO SELECT ANTENNA A AND B. WITH THE REMOTE CONTROL PRESS MENU, SELECT "SET UP" AND THEN "AV CONNECTION HOME THEATER" SET "AV NETWORK" TO "OFF" AND "TV LOCKED TO INPUT 1" TO "NO" THEN EXIT THE CUSTOMER''S MENU, TURN THE UNIT OFF UNPLUG IT AND THEN PLUG IT BACK IN, IF THE PROBLEM RETURNS AN E2 RESET IS NEEDED. ACCESS THE OPTION MENU BY PRESSING "MENU 1, 3, 7, 0", USE THE ADJUST BUTTON TO SELECT "E2 RESET" AND PRESS "QV". IF THIS IS NOT RESOLVED BY THE E2 RESET REPLACE THE EEPROM, IC701 PART # 275P163010. THE E2 RESET IS ALSO NECESSARY AFTER REPLACEMENT OF IC701.
Good Luck, big IRISH.
SOURCE: hitachi ultrascan HD tv 43 inch
Good Day;
If you don't hear the relay click suspect Q003. No power suspect Q912, Q914 & I901. Good Luck, big IRISH.
SOURCE: PROBLEM WITH GETTING LOCAL hd CHANNELS
You need to have a set top box.
By law, as of March 1, 2007, almost all televisions should include a
built-in tuner (called HDTV, digital, or ATSC tuners) that can receive
high-definition programs over the air by simply connecting an antenna. Your HDTV doesn't have such a tuner, you'll need to connect an
external tuner (or cable or satellite box) to watch high-definition
programming. External over-the-air HDTV tuners currently cost at least
$150.
SOURCE: Philips HD tv has no picture
common fault this , normally the fuse has failed on y-main board due to shorted thick film unit
unfortunately its not a cheep repair job.
