The compressor will just continue to run and run but pressure wont exceed 60lbs. there are no air leaks that I can tell.
Unplug it and listen for air leak. What pressure does the manual tell you it should run to? The safety release could be bleeding air, listen for that, with it off. Make sure it is designed for more than 60 PSI by manufacture.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
SOURCE: my sears 2hp 15 gal compressor runs but pressure wont exceed 60lb
compresors pump, valvs or sels gon!
