The TV will likely require a Satellite TV converter box. The output of the box should be mated to the best matching input of your TV.
That order would be: 1) HDMI, 2) Component (RGB) + Stereo Audio, 3) S-Video 4) Stereo Audio, 5) Composite (Yellow) and Stereo Audio 6) RF (Coaxial).
When selecting 6) RF (Coaxial), you would normally select an output channel on the Sat Box (Ch3 or Ch4) and set the TV tuner to the same channel. A standard coax cable would be installed between the Sat box connected and the TV Ant connector.
All other TV inputs would match the one you used (HDMI, Componet, etc.
Be aware though. Your TV has a DVB-T tuner. It picks up the Freeview standard definition (SD) channels, but not the Freeview HD ones. Dolby Digital sound only comes from the Freeview HD channels.
Your TV will pass Dolby Digital from any source connected to a HDMI port to the Optical Out. It will also pass DTS. But the internal Freeview DVB-T tuner doesn't generate Dolby Digital, just stereo and stereo with Dolby Surround encoding where you use ProLogic II for decoding.
the above mentioned make and model # unit is a tuner, not a reciever, as a tuner, it's only function is to recieve radio signals, there is no internal amp, no selector switch for other components.
It could be a bad interconnecting cable OR the fact that the connector inside the unit has broken solder joints. That is why these types of units that I have worked on often have many problem in that the wave soldering used in manufacturing is not made for a lot of abuse or thermal cycling. The problem can be solder by getting into the unit and applying the correct amount of solder onto the connector using good old Kester 44 not the cheap other stuff.
Since you have 2 receivers, you can either use the Sony STR-AV570X or the TA-AX380. You will need 3 Stereo RCA Cables to connect your CD Player, Tuner, and Tape Player. The speakers connect to the receiver you choose using the speaker input terminals.
Here is the diagram (click on picture to enlarge):
Without the model number of your super tuner, it's not possible to point you to a specific location for the wiring diagram.
I'd start with Pioneer support to see if they have a download for the manual. If that fails, try the manualsonline site. Manualsonline is not a free site.
The freezing of the picture denotes a loss of signal on a digital (Having a ATSC tuner) TV. If your TV is not digital (Having a ATSC tuner) then it is the device that you have connected to the TV (Cable Set-top Box, DTV Tuner, etc). In the likelihood that it is your TV I would suggest getting a better antenna first if that does not fix the problem you may have a tuner problem. However lets not look at it that way first. What we need to do is to determine if it is the TV of whatever you have connected to the TV.
First unhook the connection you have from the cable to your F connector of the TV (you should see snow or a blank screen) connect a antenna to the F connector of the TV, do you see a snowy picture or a clear sharp picture (snowy= NTSC tuner, clear-sharp= ATSC tuner). If the tuner is NTSC then check you cable device and the connection between your TV and the device and the cabling between the device and the wall. If the Tuner is ATSC then you will have to check all of your connections, and finally if the tuner is bad it has to be replaced by a qualified Tv repair shop.
